Question about EliteGroup G320 Notebook
The power indicator turns on but there's no display and still there's no response with the motherboard
When i turn it on in the mornin it suddenly appears nothing, i dont know why this happen so anyone wants to help me pls!!!
Hi, my daughters had the same problem, this might be hard to explain, when you open your laptop way at the bottom of the screen there is a little prong that goes in to the key board to let the laptop know its opened you need to get a tooth pick and just poke it lightly and screen will turn on again! Just like when you open the refigerator door and the light comes on, in your case the button is sticking.
hope this helps.
GOD BLESS
Posted on Dec 07, 2008
  • 3 Answers
Find the solution here:
http://www.fixya.com/support/t890498-laptop_power_elitegroup_g320_pc_notebook
Posted on Jan 23, 2010
Engenius handsets won't respond
Will likly cost more to repair that replace. Sorry, that is the way our society is today....throw away what dosen't work.
Jul 27, 2014 | EnGenius DuraFon 1X Handset DuraFon 1X-HC
When i turn the power on,on my toshiba satellite l445ds5976 the only thing that comes on is the power indicator light
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Ultimately, your motherboard could be faulty.
If your system is powering, but no display, connect an external monitor to see if the display itself is the problem. If an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
Feb 26, 2011 | Toshiba Satellite L455DS5976 Notebook
My linksys wireless g router will not power up,n yes I have plugged it in but no lights are comin up on the router.it was fine this mornin but turned the the plug of as I left the house come home turned...
Try to connect the router to a different outlet and try to turn it back on, if nothing happens, theres a possibility that there is something wrong with the routers power supply.
Hope this will help... Your response is very much appreciated...
Jan 26, 2011 | Linksys Computers & Internet
Computer suddenly turned off and will not power up
1. Try removing the battery and plug in the AC adapter
2. Check if the LED indicator is lighted.
3. Press turn On
If its still not working:
you have to replace your laptop motherboard
Power supply defective
Thanks. Cheers!
Apr 12, 2010 | Computers & Internet
IBM R51 display to base unit connection cable problems
your computer affected by some viruses, scan w/ anti virus
Dec 26, 2007 | Lenovo ThinkPad R51
Will Not Turn On
I would try to re-seat the BATT and or RAM.
Nov 11, 2007 | IBM ThinkPad X31 2672 Notebook
PC with ASUS P5LD2 Motherboard suddenly become inactive
That seems to be an odd problem, my recommendation is just to check the basics.  Test the power supply.  Make sure the memory is well seated.  Run memtest 86 and prime 95.  And if you have more than 3gb or ram take some out and try it, xp gets touchy if it has over 3.
Oct 14, 2007 | ASUS P5LD2 Motherboard
EliteGroup G320 Notebook Logo
494 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
