Question about Magic Sing Along Consumer Microphone
ED9000 my microphone full down on the floor.since then the sound doesn't work at all.is there any place that could fix it .because i heard only static sound maybe some wire is out.
  • 4 Answers
I think most probally the wire connects to the mic unit is shorted or some solder has loosened
Posted on Aug 13, 2008
Weak audio static uc2-ub handheld
Sounds like either local interference or it needs to go to Shure for repair. Can you try it in another location maybe 10 miles or further away from the present location. If it operates in the MHz band you need to replace it, it is illegel to use that band in the US..
Mar 13, 2012 | Shure Beta 87A Professional Microphone
I help run the sound at my church. We have two wireless microphones. One for the singer and one for the person teacher. We record the service and during service people in the congregation will make...
I do not know if an overhead microphone will work satisfactory for your application, unless you have several of them placed in the ceiling or it is a small room. You can use a boom with a shotgun microphone to direct it over the speaker. You may want to consider a parabolic microphone which is highly directional gathering sound from the direction it is pointed in. You may have to have an individual point the microphone at the speaker, and it known to have a poor low frequency response. You can look at the diagram from the below link and try to experiment with a cooking wok to see how it works.
http://mineroff-nature.com/nature/sme-pr1000-parabolic-microphone-p-187.html
The better parabolic microphones will have a bigger dish and price tag with a directional microphone or a shotgun microphone.
A parabolic microphone is what is used by the media for outdoor sporting events which you can see at football games on the sidelines to hear the players on the field without a lot of crowd noise from the spectators.
Jul 21, 2011 | Audio Players & Recorders
The monitor doesn't have sound and microphone It doesn't play any sound ,music or tones
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it:
if your computer came with a motherboard disc the sound drivers could be on it:
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps:
Jul 07, 2011 | Computers & Internet
Basically we are getting a static sound every now and again. I think it has to do with the wireless signal because it only happens when the room is filled with people not when the room is empty. How can...
Try moving belt pack around on person (speaker) and try moving receiver closer to person speaking, also keep receiver elevated, off floors and antennas need to be up. Wireless signal is like "line of sight" and if there's a ton of obstructions you're cutting signal strength. Also make sure you ALWAYS use fresh batteries, weak batteries will do the same.
Feb 25, 2011 | Sennheiser MKE105S LAV MIC w/PIGTAILS -...
When i turn the volume up or down i get a static noise, and when I try to use the microphone i get no response. I know the sound is working because i can hear music with static, but the microphone doesn't...
The static noise may be caused by dust! To clean it out spray some Servisol video 40 into the volume control and move it up and down. If it goes away it was just dust.
The mic is another thing. The only thing I can think off ist that it's got switched off somehow on your laptop. Or either the control panel slider for microphone input is set to low?
You can get Servisol from Radioshack USA or Maplin UK or that type of shop.
Nov 28, 2009 | Razer Barracuda Gaming Headset
Acer One 8.9 Netbook microphone doesn't work.
If you say that the sound and mic was broken from the beginning, maybe the guys from the service didn't replace them. You cannot do anything by yourself. Try to give them the laptop back to fix it.
Nov 05, 2009 | Acer Computer AOA150 Notebook
People can hear background noises on my PC but not my voice
Perform some simple steps as follows.
1. Double click on the volume control icon in the system tray, that is on the right hand bottom side of the screen. Check if the microphone is muted.
2. Right click on the same icon, and select "adjust audio properties." You will now get a window that says Sounds and Audio Devices Properties. Click on the tab named voice on top of that window, and check what is selected as the voice recording device. Check in the drop down menu to change the device and use the "test hardware" option to test the mic.
3. Make sure your microphone is working fine. Other people are not hearing your music from your microphone, but from your system itself.
Get back if you have additional questions.
Jun 15, 2009 | Logitech 250 Headset
I cant talk
-> make sure mic is connected correctly in the correct slot to the CPU
->go to control panel-> sound and audio and there is seperate tab for "microphone"-> have th volume to be full
-> you can test whether the mic works there itself.
Nov 10, 2007 | Labtec C-322 Headset
Sound card dell xps400
I don't think many people have a trouble free web cam, whatever make or model of pc or web cam. I get echo and feed back; if that's wot you mean by static, or do you litterly mean static. Helps to have your volume down a touch and the person who you are speaking to also, especially if it has a built in microphone(sorry, not checked your model), a seperate microphone is best as it's away from any possible speaker feedback from your pc's speakers, or any other clse electrical interference. Hope this relieves it a little.
Oct 16, 2006 | Logitech QuickCam Communicate STX Personal...
Magic Sing Along Consumer Microphone Logo
117 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
Lyle Siemens
Lyle Siemens
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
