Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Have sound, no picture
Bought this TV about 4 years ago and am on the 4th bulb, which was recently replaced. Last night while trying to view a Comcast "On Demand" show, it went blank. This has happened a few times before, but I have always been able to get it working again (but not sure how). I have hit every button on the remote with no luck. I don't think the lamp is bad, as I can hear the sound, and see glimpses of a picure when hitting some buttons. Any suggestions?
After fooling around with all of the buttons, and disconnecting the power to the TV, it occured to me that it may be the Comcast digital cable box. I unplugged the cable box for a few minutes, plugged it back in and the TV works just fine!
Posted on Jul 22, 2008
Bulbs keep blowing
You may be touching the bulb (ampule) and leaving a fingerprint on it which creats a hot spot and blows the bulbs up prematurely.
Mar 25, 2013 | Mitsubishi WD-65731 65" HDTV
Vertical lines
I called a local tv repair shop he said that he'd have the see the unit to give an exact price but their labor rates were from $79.95-$179.95 + parts =(
Jan 10, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Rca 32 rca 32
The repair of this problem will be near to or exceed the cost to replace it with a new flat screen. With TV prices at an all time low due to slack demand it is not cost conscious to repair it.
Jan 24, 2012 | RCA F32650 32" TV
Replaced the optical block a few years ago to correct the yellowish hue problem. Recently I had to replace the lamp. I had bought one new about 2 years ago. I put the lamp in and the TV is much dimmer than...
Lamps only last Between 5,000 hours some last 8,000 hours
So what that means For Every hour TV is Playing it is burning up hrs of lamp. These sets are not like projection that you can run day and night .
Most Lamps need replacing every 2 yrs Depending on how many hours you watch TV?
It could be that the Lamp you have is defective ,Mats has Lamps for $99.00 1-800-628-1118
Get New Lamp then see if that corrects the problem.
Sep 18, 2010 | Sony KDS-R50XBR1 50" HDTV
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Sound went out!
Have the audio signal board replaced. Also make sure ur amplifier is set to the correft output, alth i am sure u have.
May 03, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
No video but there is audio after replacing bulb
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
Mar 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony wega KF-50WE610 went dark...
If you have not changed the lamp in the 4 years you have had the tv you will need one soon if not now. is sound from tv or receiver, when the lamp dies usually no sound from tv. If you have sound from the tv try unpluging power from wall to reset and try again
May 16, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Unotron optical mouse under Vsta HPrm !
The Unotron CS5100 range was discontinued some 3 - 4 years ago and replaced with the WS5100 so I am guessing that the one you have would not support Vista.
Have you tried contacting the place you bought it from, maybe they will switch it for you?
Jon
May 06, 2008 | Unotron (CS5100KR-B) Keyboard and Mouse
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
