Question about RCA 32V420T 32" TV
Rca 32 inch tv
Tv will gon on and off and change chanels by itself please help
  • 2,427 Answers
Its proberally the main controll ic, or the remote sensor is malfunctioning. you will need to check the remote sensor by disconnecting it,, and if you still have the problem then you will have to change the main board.
Posted on Jul 22, 2008
42 inch rca turns on and off when on every button on remote changes chanel and the buttons on the tv itself do not work at all ive unpluged them no change it just continues channel surf on its own
Main system control memory IC fault. Check and replace it. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Dec 18, 2015 | RCA Televison & Video
Tv won't change from chanel to chanel
Do a hard reset to this set and check first. To make it hard reset, unplug the set from AC mains wall socket, and re-plug it back after 10 minutes or so.If this do not help you, check and replace its main system memory IC.
Sep 29, 2012 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Tv shuts off by itself
change ur remote batteries, if no work still remove batteries see if help
tv may have a bad remote sensor, the sensor that tell tv go on, off, change chanel , change volume.... and so on.
or ur tv motherboard
or may be try factory reset ur tv if tv program bugged.
Jan 28, 2012 | Televison & Video
How do i reset my lc26dv20 u back to factory so that my inputs will work
Just unplug,replug the tv back about an hour later.The tv now,it is resetting back to the factory setting.If ur tv still have the same problems,ur tv Tuner signal board itself is the causes and the problems,must be change the tv Tuner signal board it self,if u want the tv to be fix.
Apr 27, 2011 | Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
I have an TV Phillips L01-1UAC-7638, the issue is, when I turn on the TV, after 15 or 20 seconds the TV turns itself off, but if I change the chanels the TV does not turn off, I mean if the TV is showing...
Hi, you don't mention the full model number, there should be a number on the back of the TV something like this 27PT543S37A, the problem you have seems to be fairly common and if this is your model number you could try this, on philips model 27pt543s37a will not power-up without changing channels for 5 minutes, transistor number 7461 is leaky between collector and base - needs to be replaced, and a capacitor rated 47 uf (microfared) at 25 volts, should be upgraded to a 47 uf at 63 volts, with a temperature rating of 105 degrees vs 85 degrees.
Hope this helps, I am assuming that you are able to use a soldering iron etc.
If you have no experience in electronics/soldering or how and where to get parts please consult a TV technician, dangerous voltages can lurk about in a tv even when not plugged in so please be careful and if at all unsure leave it to the people that know!
Feb 09, 2011 | Televison & Video
My Goodman tv..When I change chanels I get sound but no picture. If I Turn it off and change chanel then turn tv back on I then get picture,Please can you help me withmy problem.Pat
Ocassionally. digital TV did not load correctly, and must reboot and load firmwware to get the digital signals for the TV. Changing channel is not necessary for firmware to load correctly. But powerline glitches might cause a problem..
Nov 17, 2010 | Televison & Video
Vizio tv chanel search is not finding digital chanels.
On your remote, select input as TV, then verfiy that you have set to Antenna, Then scan for channels.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
Changing channels by itself
bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
Oct 05, 2008 | Beko 324250WN 28" TV
RCA 32V420T 32" TV Logo
278 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
