Question about Cameras
Flas Control Olympus E-500
What am I doing that is incorrect? I just cannot get the bottom row of choices that appear on the "Flash Mode" screen (full, 1/4. 1/16. 1/64) to light up. Rotating the control dial cycles through the four choices on the first two lines, but never illuminates the choices in the third line. I have the mode dial set to M, iso to 100, focus to S-AF. and flash set to on (no red eye, no slow curtain etc.).
  • David Cuge;; Jul 22, 2008
    Yes, this is the same problem I previously posted. None of the several responses provided a solution. My camera is an Olympus E-500
    Guru:
  • 1,894 Answers
I think you are posting the same problem again?
please check
Posted on Jul 22, 2008
  • dewan nafees ahmed Jul 22, 2008
    keep model dial to M and iso to HIgh and keep focus at S-AF
    it must work.
    if it does not work then it is a problem with the software of your unit.
    you will need a re-installation from service people
When take picture a flashing green light appears on display
Check that batteries are fresh. Check that camera hasn't been set for no-flash mode.
Give the flash time to charge before pressing shutter.
Aug 21, 2013 | Olympus EVOLT E-500 Digital Camera
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
button.
If you are in any other mode the flash will not auto pop up.
Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
No flash on Olympus C-740 Ultra Zoom
This does appear to be a settings problem...
On the 710, there are a number of settings combinations that will result in the flash remaining off.
Here are some that I can think of :
> If the camera is set to "Super-Macro", the camera will not allow you to turn on the flash.
> If you are shooting using any of the scene modes, watch out, because several of these can set the flash to "off", and may not allow you to override that setting. Try exiting "Scene" mode, and try setting the flash.
> If you are shooting using the "Guide" mode, be aware that several of the options there will set your flash to "off". But (in my experience) you usually can override "Guide" mode's flash settings.
This one is important>>> If you are shooting in the "Auto" mode, the camera will always decide whether to flash, and you can not alter its decision. The way to escape this tyranny is to shoot in the "Program Auto" mode. This setting is not located in the same place as all the others, at least it is not accessed in as direct a way. Try this :
>>With the mode selector switch (dial) positioned to indicate the picture of the little camera (and with power on), press the "OK" button in the middle of the 4-way controller. Now you can see the "Shooting" menu.
>>Use the bottom (down) part of the 4-way controller to scroll through the options...you are looking for the one that gives you a choice between "P" and "AUTO". Stop scrolling when that location is highlighted. Now you can use the right or left parts of the 4-way to select between the "P" or the "AUTO". Be patient here, as the camera's shift from one setting to the other can be sluggish, and if you press the button just fast enough, it will appear that no change is taking place. Be sure to select "P", and press "OK" again. Now you should have regained control of your flash settings...but to exercise that control, you will, of course, have to be in normal shooting mode (the picture of the little camera), and press the right side of the 4-way controller to open up the flash settings screen. There, use the 4-way controller and the "OK" button to make your selections. Consult your manual for the meanings of the symbols.
If it is not one of these, it may be still be a combination that I haven't listed...or it may be something more serious. I hope this helps, and good luck!
Dec 25, 2008 | Olympus Stylus 710 Digital Camera
Flash-Off Problem
Do you have the camera in the auto mode?
Did you check to make sure that the auto focus is not in the manual mode when the flash is turned off?
If the above does not comply, call the tech support for the camera.
There is also a possibity that there is a defect, or that the flash is part of the auto focus function.
Jerry G.
Sep 15, 2008 | Olympus ? Stylus 500 Digital Camera
Flash Control Settings
try to reset the camera and check
Jul 21, 2008 | Cameras
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
How do I reset?
It sounds like the strobe is not making good contact with the connection on the camera. Check to see if the pins on the camera aren't covered with crap and the pins on the bottom of the flash aren't bent or broken.
Good Luck.
mwh2385
Feb 25, 2008 | Olympus EVOLT E-500 Digital Camera
My Olympus Stylus 500, doesn't work the flash
hi
have you tried using lithium batteries? alkaline batteries. just try out different batteries. if it is still the same, have your camera checked in a service center for maybe it needs a replacement or there is something loose inside.
hope this helps.
Jan 28, 2008 | Olympus ? Stylus 500 Digital Camera
Olympus Stylus 710- no flash mode
I;ve been on the internet all morning researching the same problem. It appears it's a curcuit related problem with the flash. As of know, haven't got a solution other then buying another camera or taking paictures in manuel mode without flash.
Nov 25, 2007 | Olympus Stylus 710 Digital Camera
Flash indicator keeps blinking
i have the same problem. i dont think the flash is working.. i think the bulb needs replacing. i wish i knew a place to get it fixed or a place to buy a bulb...
Aug 05, 2006 | Olympus ? Stylus 500 Digital Camera
Cameras Logo
60 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
