Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Brown material when my washing machine starts to spin little brown particles appear. Not sure what they are? The water was tested and nothing was found. Can you help me fix this
  • James Crossen III Jul 22, 2008
    It appears that the finish at the top of the steel drum has delaminated and causing rust to flake off of the drum into the water.
    Look at the top edge of the drum next to the rubbr lip seal.
    I'm afraid if I pull on the glazed paint I will expose more of the steel drum and rust will realy start to fall into the drum.
    Unit is approximately 5 yrs. old. Used 3 to 5 times a week. Tide, Clorox and Downy only.
  • 868 Answers
I f you use liquid fabric softener you will get allot of weird things inside the machine building up and eventually falling off onto the clothes.Rust will also have the same effect,if you can see it ,sand it off ,and cover the area you sanded with a sealer and let dry for 24 hrs. Please Rate This !
Posted on Jul 27, 2008
My WMS38 Hotpoint washing machine has the wash, rinse and spin and final spin lights on but nothing happens when the start button is pressed
Assuming tap water is turned on. If there is no water intake, the machine will not start. Check for the sound of water pouring in the machine. Check the water inlet filter, if it is jammed with foreign materials such as rust deposits, small stones, soil etc. Then check for the proper functioning of inlet water solenoid valve. Sometimes the valve gets stuck.
Nov 25, 2011 | Hotpoint Washing Machines
Whirlpool washer wet after spin cycle
Hello.
1 Measure your drainpipe to make sure it is no taller than 96 inches in height and no shorter than 30 inches; otherwise, it won't pump enough water from the washer, or the water may flow back to the washer.
2 Look at the dial selection to make sure you have selected the proper spin speed for the material you are washing. Choose the highest spin speed for that particular material. If you choose the "no spin" or "low spin" option, your whirlpool washer might not remove all of the water from your clothes.
3 Check if you have chosen the appropriate wash cycle for the type of material you are washing. The whirlpool washing machine drains quite a bit more slowly on the "Delicate" and "Hand Wash" cycles.
4 Check for excessive soap suds accumulating in the washing machine. whirlpool recommends you use only high-efficiency detergent in whirlpool washers. Other detergents can cause excessive soap suds, which could cause the washing machine to operate at a slower spin speed than selected, resulting in sopping wet clothes.
5 Add more clothing items to the washing load. If you wash only one large item, like a coat or blanket, the washer might become unbalanced and react by lowering the spin speed, causing the machine to not drain as it should during the spin cycle.
6 Examine your drain hose for clogs or kinks. Straighten the hose out to allow water to flow through. Eliminate blockage in the drainpipe or utility sink.
Thanks.
Nov 01, 2011 | Washing Machines
I have a 1988 Hotpoint top-load washing machine, Model # WLW 3500B. The water supply on the hot side appears to be constricted with very little flow. I checked the screen in the water supply hose and there...
Hi Eric,
Have you taken off the hose for the hot water at the back of the washer and then run it into a bucket to make sure the flow was good there?
If you have great flow there then the problem is in the washer...
If not then it is in your plumbing...you will need to track that down and fix it...
If it is in the washer then you probably have a problem with the fill valve or solenoid valve that opens to let the water in...they can either stick or get dirt lodged in them...either way replacement is probably the best option...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 07, 2011 | Hotpoint Washing Machines
My washing machine will not spin the water out of my clothes,what is the problem?
Have you washed any rugs lately that may have shed some material? Is it making any unusual noises? Is there any standing water in the drum?
Not sure what type of machine you have but it sounds like the pump inlet is either clogged or the pump is inop. With a little more information we may be able to narrow it down.
Jul 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
Jan 13, 2010 | Hotpoint Washing Machines
Frigidaire FWX233RES4 washing machine won't work
Sounds like there's something such as a small sock that has gotten sucked into the pump. This will keep the pump from spinning, cause extra noise, and the belts may appear fine but it may be stretched... if you're willing to deal with a little disassembly, unhooking hoses, spilling some water, you can probably handle this.... Good luck and let me know if you need any more assistance..
K
May 10, 2009 | Washing Machines
Odd messages appearing on lcd screen and not collecting water
What make and model is your washer?
Cannot help without further details
Nov 19, 2008 | Hotpoint Washing Machines
Kenmore series 70 washer
Dear Customer,
please rate this solution if it meets ur needs, else choose fixya..
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Drum does not spin
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
No water is entering the wash tub
or no hot water
or no cold water
Washer does not work but it does make noise
please rate this solution if it meets ur need, else choose fixya.Thank you..
Nov 11, 2008 | Kenmore 22422 Top Load Washer
Hotpoint WMA50p won't spin
Had same problem today with our machine. Brushes looked OK (although one appeared a little shorter than the other).
After removing and re-fitting the brushes, motor worked fine - suggesting that it was the brushes afterall.
Now looking for replacement brushes
Feb 19, 2008 | Hotpoint WMA50 Front Load Washer
Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Oct 15, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
