Question about Friedrich QuietMaster Deluxe RS12L10 Air Conditioner
A/c my a/c comp. is not running , only the fan
  • ytnoma Jul 26, 2008
    The thermostat switch was bad.
  • tama samoa Feb 06, 2009
    My problem is the circuit breaker opens when the compressor come on to cool. I have no way of checking the capacitor but, it looks fine, no deteriation or loose, burnt wires... Any suggestion? PS I need some ideas...
  • 80 Answers
COULD BE A BAD BOARD, BAD RELAY, BAD COMPACITOR NEED MORE INFO TO HELP YOU
Posted on Jul 22, 2008
SOURCE:
Muz series led flashes twice
58 volts is not enough to run a compressor either your meter / reading is wrong and there should be no voltage on compressor terminals when disconnected .
Nov 22, 2014 | Heating & Cooling
The temperature will not adjust. none of the refrigerators are getting cold but fans are running
Sounds like you may have a compressor issue to me. if the fans are running that tells me the tstat is calling for cooling and the fans are running so they are fine. The comp is not producing cooling for some reason. Can you see the comp and tell if its running or not?
Aug 14, 2013 | Husky HUS-CN15 Wine Chiller
The unit is not cooling down.
is the unit running? are the fans running? if the fans are running then check to see if the comp is running. If the comp is running you have a more serious issue. if its not or nothing is running im suspecting a control issue
Aug 14, 2013 | Summit Commercial Summit Professional Wine...
In between doors on side by side fridge is hot. Whirlpool GD5phax
you need to fix the fan down by compressor as it cools the cond coils and causes proper orp of cmpressor . if it not running the comp runs too hot and does not pump the refergent and may be shutting of on overload . the high tempt between the doors will be less with fan working . but some warm tempt is normal .. mm
Jul 29, 2010 | Whirlpool GD5SHAX Side by Side...
Refridgerator not cooling. Motor is on Fan is on Coils are not warm. Could it be the thermostat?
if colis are not warm or some what hot . the compressor is not running . compressor runs when the fan is on feel the top of comp see if its hot . this may be a bad comp relay .. if not running .. some times you can hear a clicking sound about every two or three min . this is the relay trying to start comp .. mm
Jun 21, 2010 | Refrigerators
Nc6000 comp. will only run fan when turned on for
RAM shaken.
Go to service centre and they will readjust it for u.
Apr 16, 2010 | HP Compaq nc6000 Notebook
Does not make cold, main compartment or freezer, replaced "relay/overload" capacitor (?) but still cycles/clicks off and on - lights on and motors run but no cold.
if clicking off and on I would say . the relay is working but the compressor is not starting . if comp will not start ( no cold ) the fan by the comp runs when the comp runs / but if comp does not start the fan does not know .. if comp runs the lines one is small and other is larger . the small one gets hot enough not to touch.it . not hot no cool . I think you have a compressor problem .. **** hope this helps . get back with me .. //mm
Jan 06, 2010 | Amana ABB1921DE Bottom Freezer...
Whirlpool top freezer bottom fridge
check if compressor is running if no check thermostat , bypass thermostat if comp starts change thermostat. if comp does not start call repair man as comp will have to be changed, major operation.
If comp is running OK then check evap fan motor
Oct 16, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Friedrich QuietMaster Deluxe RS12L10 Air Conditioner Logo
85 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
acidjazzok
acidjazzok
Joshua Jennings
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
