My lcd tv doesn't work at all (doesn't even turn on). I think there might have been a power surge through the outlet it was plugged in. Do you think that I might need a new power board?
  • 979 Answers
Hard to say as surges are rather indiscriminate on where they travel through our electronics. Consult a local tech on further information; Sorry I wasn't more help...accordianman
Posted on Jul 22, 2008
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Unplugged my 32LV67U to vacuum behind it and now it will not power up. Yellow LED keeps blinking and I waited several minutes but tv will not power up. Worked perfectly until I unplugged it. Called...
That wall outlet may have frequent surges so try another wall outlet see if it turns back on. If it turns on be sure to use a surge suppressor and never plug the TV directly into the wall outlet. The AC surges will kill the power supply of the TV in short time. See if there's a kill-switch near the ac adapter of the TV if there is turn it on.Get a surge protector/suppressor then try plugging it back in the wall. If still no power then the power board is already damaged, you can send the board too me and I'll repair it for you or seek your local repair center.
http://tvtechwork.webs.com/
Oct 18, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Had a power surge through my house tv picture went out I think there is still sound but no picture anysuggestions
make sure to plug in all major electronics and appliances to a very nice surge protector. If you have tried the TV in other outlets that you know work, and it doesnt display anything. It is probably power supply.
Sep 17, 2010 | Digimate DGL32 32 in. LCD Television
Have an insignia tv that won't power on...was off..made popping noise...won't power on. checked power in both the surge protector it was in & wall. all other items plugged into surge protector work....
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Insignia NS-LTDVD19-09 LCD TV
Olevia 37" no picture
check the TV power cord first., try to plug any other appliances on the same surge protector or outlet, like electric fan, electric iron., see if's work., if it does, probably the power supply of your TV is in trouble.
May 09, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Samsung LN52A650 lcd will not turn on after power
open it up / there should be a glass fuse replace it/ull find it were the mains lead goes on the board/also try new lead just incase
Dec 26, 2009 | Samsung LN52A650A LCD TV
The tv died
My ilo Does This Every time We Have A Power Outage Did You Reset It????? Unplug The Tv And Hold Down The On Off Power Button For 30 Seconds Then Release And Plug It Back In And Check.
Jan 07, 2009 | iLO 3200 32 in. LCD Television
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
