M letter on gateway laptop not working
All keys work on my laptop except the m key
  • 2,028 Answers
Start by taking the key off, be gentle and try to leave the retainer on the board. Check to see if the rubber depressor has shifted, is stuck in the depressed position, or has some dust/dirt in it or on the contact point. Cleaning the depressor or the contact point wouldn't hurt either. Check the contact point by pressing it with your finger or a pencil eraser. If the contact point works, then put the key back on and try it. If the depressor is good, then check the keyboard connection, they will sometimes work loose or get a little dirt/corrosion build up. If the connection is good, then I'm afraid a keyboard replacement is your only option.
Posted on Jul 22, 2008
Have a Gateway M285e laptop that the letter 'e' on the keyboard doesn't function. Will cleaning the keyboard resolve this issue? Thanks
It is possible that there is something sticky keeping the "e" key form working. Removing the key and cleaning around it carefully with alcohol or alcohol water 50/50 or 100% mix might free it up. Use Que-tips or something like that. try to clean around it first. If that does not work try gently lifting up on the key with a small screw driver or knife. You may hear a small pop. this could go either way for you good or bad, so be car full. then try cleaning around the spot ware the key was, gently replace the key.
You may also consider plugging in a cheep $10.00 key board and see if this works. I spilled a large drink in min and needed to use an auxiliary key board until I replaced the computer.
Apr 12, 2015 | Gateway Computers & Internet
Gateway NV59hu series laptop keys stop
have you spilt something onto the keyboard at all?
Sep 27, 2013 | Gateway Nv57h57u Laptop
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Feb 17, 2013 | Computers & Internet
Do i have a faulty "A" key or a faulty keyboard?
You will need to purchase a keyboard replacement. Thanks for using FixYa! You can purchase them rather cheap at
Feb 06, 2012 | Dell Inspiron Computers & Internet
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
Where can i find a repair manual for a gateway mx6943m laptop?
certain letter keys on my keyboard are typing out numbers instead of letters? Have i accidently hit a key to make this do this? How do i fixx it?
Dec 23, 2009 | Gateway Computers & Internet
One letter on keyboard does not work
if this is a pc and not a laptop pop the key out and press the pad under neath to sea whear the problem is
Oct 28, 2009 | Gateway 2520915 Keyboard
7330GZ Gateway laptop keyboard doesn't work
There is one thing you can try. Uninstall the drivers for the keyboard from the device manager, then reboot. The machine will find the keyboard and reinstall the drivers automatically. If this doesn't work, then I'm afraid the Shift key function has failed and the keyboard will need replaced in order to fix it.
Aug 25, 2008 | Gateway 7330GZ Notebook
Mt3705 keyboard problem
You probably have the function scroll button on. See the blue numbers on the letters? press function scroll to take it off and see if that is your problem.
Jul 23, 2008 | Gateway MT3705 Notebook
Sticky keys
Dear rwertheim
Try the following guide
There are no guides from Gateway for the keys available for the but this guide will be more than enough to help you through this one in order to remove them. Its should be completely the same principle.
Cleaning the keys should be done without alchohol based cleaners because the lettering might be erased. Use some soap and warm water instead and gently scrab with a soft brush the bottom of the keys.
Please remember to take out your laptop battery/ac adaptor in any case since you will be working at hardware level with your equipment.
Regards, and I wish you no more sticky keys!
Please dont forget to rate this solutin!
Apr 02, 2008 | Gateway MX8711 Notebook
Computers & Internet Logo
454 people viewed this question
David Payne
David Payne
