I have a 26" Sanyo model DP26648 that I bought at the end of May. It has worked fine until right now. The I was watching a program when the screen suddenly went bright white. There was sound, the channels changed, but nothing but white. I have DirecTv no HD. I checked the booklet. Tried pressing reset...now nothing...not even sound. I unplugged it for a few minutes. Still white screen. What now?
  • 979 Answers
Chances are you have a bad regulator or regulator circuit related problem, as the screen is showing extremely bright.....accordianman
Posted on Jul 22, 2008
I last the tv remote model dp26648 i want remote
Setup codes to check with Sanyo brands are 004/ 013. If you wish to get more details about four digit and five digit codes, check this link. There is setup code list to many brands of remote controls. Just see and check which brand has setup code to Sanyo. It will make you remote selection easy. There is an other link. Check this too.
Feb 20, 2013 | Sanyo DP26648-R 26 in. LCD TV
Neither "solution" is a solution. Anyone actually
Your problem is the T-con board. This is gone bad/faulty. I would advice you to replace it with new T-con board and your unit will back to normal again. You may look for the replacement online. Try ebay.com or shopjimmy.com.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 16, 2011 | Sanyo DP26648-R 26 in. LCD TV
Remote control code for Sanyo DP26648
remote is worn out cannot change volume, channel , check info etc most buttons have stopped functioning I need code to set up universal remote need it now.
Apr 12, 2009 | Sanyo DP26648-R 26 in. LCD TV
I need to hook up to digital cable
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
Apr 01, 2009 | Sanyo DP26648-R 26 in. LCD TV
Trying to hook up my ps3
ok i have come acrost this problem with my ps3
turn the ps3 off plug all the cables in right and put the tv on the right video input now hold down the power button on the ps3 for about 30 - 60 secs or untill it beeps or you see it working
let me know if it works
PLEASE RATE thanks
Mar 27, 2009 | Sanyo DP26648-R 26 in. LCD TV
Sanyo DP26648 cable problems
I have a sanyo dp26648, just had it over 90 days and it quit. I can hear the sound, but no picture at all. Just a bright white screen. I can't even go to the menu. I bought the extended warranty but there in not anyone in my area to fix it. They told me I would have to wait until they found one close.
momdukes
Sep 10, 2008 | Sanyo HT32546A 32 in. Television
Set up lcd tv
Make sure of correct input
HDMI is best
cable box must be set to HDMI
otherwise input to channel 3
Jul 22, 2008 | Sanyo DP26746 26 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
