Question about Canon PIXMA MP460 All-In-One InkJet Printer
Cannot recognize ink cartridge
Used printer very little over period of 6-ish months, but previously worked very well. Now it won't recognize the magenta cartridge. Have only used OEM cartridges. When error received, ink tank was about 1/2 full and had not been touched or monkeyed with in any way. Replaced cartridge anyway -- still won't recognize cartridge. What now? The machine is locked up. Just a few weeks ago I bought new ink cartridges from Cartridge World. They worked find until about 4 days ago when my printer couldn't recognize the cartridges anymore.
I did not change anything or even open the cover to my printer.
  • 2 more comments
  • shellio Jul 22, 2008
    This is what I posted. I don't knwo how those extra sentences appeared...
    And yes I'm using PG40 and a CL41.
    I also have a PG50 black cartridge.
  • Robert Short Jul 29, 2008
    my pixma mp 460 will not recognise my cartridge world refill. its the cl41 colour.
  • Lord Syred Jul 31, 2008
    Same problem. Working fine one day - next won't recognise cartridges (one is fresh Canon original, one a refill). Machine under a year old but now (temporarily I hope) useless.
    BP
  • Miles May 11, 2010
    I'm a bit confused here. You have on your heading a Canon MP460. The 460 uses a PG40 black cartridge and CL41 Tri-color cartridge. Why is it you are referring to the magenta cartridge? If you replaced 1 of the colors then it must mean you have replaced 1 three colored cartridge? If you are talking of a magenta cartridge, then that means you have a CLI-8 cartridge not a CL-41. But your machines only use the 40 and 41 cartridges.
How i sort this problem out
Posted on Mar 30, 2009
    Novelist:
    Scholar:
  • 125 Answers
I have about 6 canon printers with a 3in 1 using PG40 and CL41. I have never encountered the problem you have. I have looked into some other sites and noticed a number if CLI-8 cartridges being replaced by Canon. I think there are only 2 probable problem areas, he cartridge or the software you are using. I suggest you call up Canon and complain about this problem. Seems like you got the printer 6 months or so ago. You should able to get to do something like replace the printer or cartridges. I'm assuming that you don't refill or have your cartridges refilled so the contact points should not be messy w/ ink. You can try cleaning the contact points on the cartridges and printer. But I'd call Canon and explain to them the situation and see if they can solve your problem. Solve I'm implying is to replace your cartridges or printer. Let me know if this helps.
Posted on Jul 22, 2008
Check ink cartridge on right
Yes - if they are not used they will dry up and be unusable.
Unfortunate but you need to replace them.
For future ref - IF they will not be used in 4 - 6 months
pop them out and put scotch tape on the head where ink comes out
and that should keep them good for several months..
I have done that and close to a year later - was fine.
Hope this helps :)
Sep 30, 2012 | HP Photosmart C4180 All-In-One InkJet...
Canon IP3300 won't print color
hi chette,
its a common problem for printer dye ink,have you try to use other cartridge? a brand new one maybe?
if you insist using the old one, try these step.
1. use vinegar to clean your cartridge head
2. put a little vinegar into the cartridge
3. try deep cleaning it.
it only work for dye ink base not else :D
ciaw.
Jul 11, 2012 | Canon PIXMA iP3300 Printer
Changing print color cartridge
The cartridge you have change are did not much or not compatible with your printer. You just buy a cartridge with the same brand of your previous cartridge that used and to make sure that your printer are recognize it. Because some compatible ink are cannot be recognized by other printer.
Jun 03, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Doesn't recognize the color ink cartridge
Good day!Your cartridge is the problem..even if its new or original if the printer never detected or sense your cartridge's presence..then that error will appear..
So,try to change a while or borrow if you have friends there just for reading or proven the problem..
mastergani
Apr 03, 2010 | Olivetti wireless All-In-One InkJet...
It tells me the cartridges are empty, then when i open the lid it says no cartridge! its not been used for a few months, and i refill them with generic refills...any thoughts? tried the switch off and on -...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Make sure that your ink cartridges are full and that they are genuine brother inks; refills or generic ink cartridges are not guaranteed to work properly.
Thanks,
Pat
Mar 29, 2010 | Brother MFC-620CN All-In-One InkJet...
HP printers - remove and check cartridge. (Use it or lose it)
There is no solution for HP Printers being used very lightly - meaning "not for months" etc.
As a result, if you are stuck in this predicament - an HP inkjet, that you only need every few months - I instead suggest you set a calendar entry for once a week or more and run a test page.
The printer will "hopefully" not dry out by being periodically used - and the ink "wasted" will result in a LONGER cartridge life than if you had to throw out a cartridge.
There is also a time period, or sensing of the cartridge, that results in a wasteful cleaning cycle in which it pumps ink "down the drain", and I'd like to know how often to test print to avoid that.
My solution to my most recent problem was to "give up" and throw a new (black) cartridge on it and take the barely-used one out.
Jul 07, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer says it's out of ink, but it's not!
if you refill the same cartridge that was in the printer
the printer would recognized the cartridge as being out off ink
you need to install another different black cartridge
the printer will identify this as a new cartridge
you then reinstall the previous cartridge back in
the printer will now recognized it as a new cartridge
Jun 12, 2009 | HP Deskjet D4260 Printer
Lexmark x5490 Right /left cartridge incorrect
If you brought new cartridges and printer detecting it empty ,then you get it
replaced as the Lexmark cartridges comes with a 6 months warranty ..
Good luck....
Feb 13, 2009 | Lexmark X4530 InkJet Printer
I had the same problem. I was using original brand cartridges and it was still not working. Here's how I got it to work. I recommend doing each step and then trying to print a test page to see if it is working.
1. I used a Q-tip with Isopropyl Alcohol and cleaned the gold contacts on both the cartridge and the mating contacts in the printer.
2. Then from the Setup Menu, I found a menu called Tools. From there I ran "Align Print Cartridges".
3. From the same menu I also ran "Clean Print Cartridges"
4. I then ran a few test prints by going into the Setup Menu and then choosing "Print Report" and then selecting "Self-Test Report". It prints grid patterns in black & white as well as magenta, yellow and blue. The black grid pattern had some missing lines until I printed this report a few times.
5. I made a few photocopies and now the printouts no longer have large stripes of missing ink as it did in the earlier steps.
Good luck. Hope this helps.
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
698 people viewed this question
old marine
old marine
