Question about Electrolux Washing Machines
Error code E10 on the electrolux ecovalve EWF1087 front load washer. What does this mean?
  • Anonymous Mar 16, 2014
    ERROR CODE: CLRS\\EAN TUB
    unable to reset electrolux front load washer
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Posted on Jul 22, 2008
    Master:
  • Electrolux Master
  • 489 Answers
Family code E10 visible to customers (E11,E12 and E13 only visible in service mode) means the problem with fill water during washing or drying phase.
Possible malfunctions: Tap closed or water pressure too low; Drain tube improperly positioned;
Water fill solenoid valve is defective; Leaks from water circuit on
pressure switch; Pressure switch defective; Wiring defective; Main board defective
Dado
Posted on Sep 27, 2014
Hi washing machine will not stop filling Electrolux Ecovalve EWF1087
Without seeing what make and model... Pressure hose to the water control might be plugged or tap on the control panel with a rubber mallet to see if points in that sensor are stuck. Try setting it to a smaller load size.
Apr 10, 2016 | Washing Machines
My washing machine keeps stopping during its washing cycle and says fault E10
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
Dec 21, 2014 | Electrolux Washing Machines
Why Electrolux front load making knocking sounds during spin cycle. Model ewf1087
Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Electrolux EW1200i Front Load Washer /...
Front loader washing machine EWF1087 stopped half way and did not drain, E50 was displayed. Emergency emptying out the water was done and try to restart. Could not start, still displaying E50. What to do?
the error code E50 indicates that the motor has become overheated, you should give it an hour to cool then try running the washing machine again. I'm also including a link to pdf below with the common error codes for your brand of washer in case you have any other problems
http://www.applianceblog.com/mainforums/attachments/frigidaire-electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwashers.pdf
Jun 17, 2011 | Electrolux Washing Machines
Hi I have an electrolux front loader model number E/EWF1087/W I switch it on and all the green lights flash and I have an error code reading 'err90'. Can you please tell me what this is and can I fix it...
Sorry to read about your problem, I hope this helps you out.
e90, means a bad connection. at the main control board.
you can try to open the machine and check a and clean all connections to the main board.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Electrolux EW1000i Front Load Washer
Hi, I have an Electrolux EWF1087 which is flashing an E50 error message. Can you tell me what that error message means? Thanks Gary.
HELLO GARY E50 error is to do with the motor, it can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Jun 05, 2010 | Electrolux EW1200i Front Load Washer /...
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Front Load washer with error code E10, stops before spin
10E on electrolux means water hasnt emptied before max empting time,(drain problem)it wont spin because of this,this could be the same situation even though its a frigidaire
May 07, 2009 | Frigidaire Washing Machines
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
4,639 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
