Question about Radio Shack Pro-96 Scanner
Talkgroups and control channel problems?
I have all the control channels, talkgroups and stuff programmed in, but when i scan, it picks up ALL the talkgroups and not just the ones I have programmed. I want just the ones i have programmed. Am i programming it wrong? I am using the win96 software. How can i lock out the other talkgroups if thats the problem. again, i want JUST the ones i have programmed. thanks
No, you are not programming it wrong. The reason it is picking up all the active talkgroups is because the bank is "open". Hit manual like you are going to program a frequency in. Go to the particular bank in question and hit the function , 5. The display should say bank closed. This will "close" the bank and only allow the talkgroups you have programmed thru. To "open" the bank back up to recieve all frequencies do the same thing again. Function, 5. If you have any other questions email me at and I will be glad to help.
Posted on Aug 01, 2008
My maycom scanner is stopping on a frequency,scans etc but no talking.?
Scanning may stop on channels with a carrier but no modulation (annoying) or channels where access is controlled by a code or channels arranged in talkgroups.
Feb 12, 2017 | Radio Communications
Hi, I am trying to program P-25 systems on my uniden bcd396xt scanner, but I cannot find the tgids to enter into the scanner.Can anyone help?
You should only have to program the CC (control channel) frequencies for P-25 systems. You should be able to pick up all talkgroups. Then you could I.D. and program only the talkgroups you want to hear.
Jan 17, 2016 | Uniden BCD396XT Handheld Scanner
How to tune in Channel 60 in a Sony Triniton CRT?
assuming that you can "pick up" channel 60..and that the signal is strong enuff...that is part one..make sure you have a good antenna connection and that the antenna is positioned for maximum pick up, then do the scan mode on the tv via the remote control. it will re scan the channels and if the signal from channel 60 is being picked up strong enough, it will program the channel into your set automatically.
Sep 03, 2014 | Televison & Video
Run channel auto scan
The auto scan feature scans the various channel frequencies looking for a signal. Weak signals may be picked up on one scan and missed on the next. Check your antenna or add a antenna power booster and try again.
Sep 18, 2013 | Sony BRAVIA Televison & Video
How can I program my remote with scan
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
Mar 24, 2011 | One For All URC-4021 Remote Control
800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Jul 03, 2010 | Radio Shack Pro-2096 Base Scanner
Need to program channels
This is a LCD tv right?U want to hook up free air or pay cable tv.Go in ur tv menu goto setup,go down to than pick AIR or CABLE.Than just pick one press scan u will get all free air channels or get all ur pay cable channels
May 26, 2010 | Vizio L37 Television
I have programmed my pro164 scanner using win97 software and the pc patch cable. i have frequencies programmed to channels onto bank 0. i also programmed the desired talkgroups onto bank 0. problem is when...
you will have to buy the Radio Shack USB cable 20-047 and install
the driver for it and then I downloaded a program named
"Win97" from the website as listed
on page 21 of the Pro-164 manual. The cable costs
$34.99 and with tax you are looking at about $37.88.
The "Win97" software must be registered for it to work
after a 30-day free trial period. That's approx $25.00.
This is the ONLY WAY to go !! You put in everything
on the software GUI and then upload it to the PRO-164.
Works like a champ .
but if you have tried doing this.i advise do it again.again run the program by connecting the cable again.if you have not tried it then do it again. if still the same problem.then it might be the problem with the scanner.get it rechecked from radio shack. there are many many users facing this same problem this particular model of radioshack scanner and other model in which this same problem occurs is pro-197. get it checked with radio This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 27, 2010 | Radio Shack Pro-97 Handheld Scanner
Bleed over to other channels
When you make an announcement, It wil overide other normal traffic, Announcements take priority. Assuming you are useing a 6809 controller. Look at the announcement talkgroup, with your RSS or use CAS to look at the 6809.
Good Luck., Bill
Aug 27, 2009 | Radio Communications
Edacs frequencies
Are you getting talkgroup ID's? If not, you're probably monitoring the EDACS system in conventional mode rather than trunking. When the scanner hears those beeps, it's supposed to go back to monitoring the control channel if you're in either trunking mode (search or scan). This also happens if the CC isn't coming in very well. If you're not in trunking mode, read the manual to find out more about programming and monitoring trunked systems. If you are in trunking mode and receiving ID's, the unit is probably malfunctioning.
Sep 23, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-96 Scanner Logo
167 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
