Question about Microsoft Xbox 360 Console
Wiring... I played a game and then turned it off only to return about an hr or two later and nothing came up on my input channel...i can hear the game that i put it but for some reason i cannot see it. I check all the wires the input out put slots..the red is in red yellow in yellow and so on yet nothing comes up...im playing it on a standard tv not in HD...any suggestions or anything ? ? ? thanks
  • Anonymous Jul 22, 2008
    no picture but only sound have tried other av cable and other tv
Yeah, **** your xbox...hard...cut a hole in it and *** inside it
Posted on Jul 22, 2008
I played my ps3 for the first time using my old tv(no hdmi slot)..then i try to play at my second tv (hdmi tv)& surely can play successfully.. but the problem occured when i played for the third time...
Hello,with the unit turned off press and hold down the power button till you hear the second beep then let go,about 8 seconds later video should return to the older tv.
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
How to connect effects processor to mackie 1602 mixer
Should be an Aux 1 or 2 output jack on the right side of the mixer. You can come out of the 1 or 2 OUTPUT jack to the input on your processor, and then from the output of the processor to Effects return or to a channel input. By going to a channel input you can then blend the processor's signal with a slider into the sound system with the other channels, while adding tone if needed. By going back into the Effects return, you just blend it overall by adjusting the Effects return knob.
To feed the channels through the processor, turn the AUX 1 or 2 knob up on each individual channel you want to go through the processor. Make sure the AUX 1 (or 2 if you are using that) MASTER knob is turned up on the right side of the console, otherwise nothing will go to the processor. You should see the processors' input light showing signal, if not check your connections. Good luck
Feb 19, 2011 | Mackie 1402-vlz3 Compact Mixer - 120v
Play station is hooked up on turned on (blue light) tv is on and on the right input but nothing shows up on the screen. Please help
Please try these easy steps to sort your problem out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Aug 23, 2010 | Sony Playstation 3 (PS3) Console
When i connect xbox 360 arcade[new] to my tv can't it to play
have you switched the switch to hdtv and NOT tv on the back of the big grey ariel plug going into your 360 ? then turn your tv to the aux or av channel as it wont be on a normal channel ??
Jan 26, 2010 | Microsoft Xbox 360 Console
I had a hdmi but my tv broke and im using difrent hook ups but nothing shows up how do i fix this so i can play agen
Make sure the system is turned off.
Then, hold down the power button for 5-6 seconds, until you hear a second beep.
The video settings will then be reset!
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
TV screen goes black but tv is on. But will stay on sometimes.
i have a 2000ish 32 inch trinitron Wega and i have had the EXACT same problems as you have, except mine was blacking out more and more frequently, but yes if u changes the channel or hit return onto the same channel you're watchin the picture wil come back, but not very long, about the longest it'll show a steady picture is 1/2 hr, but it's usualy going black within every 10-15 mins or so.
I took it to a Sony approved/recommened repair shop and aftet having a look i was told it would cost $200 cd including taxes to replace a 'vacuum tube' or something like that, i wish i could be more specific anout the part. I'm still considering whether or not to go through with the repair. I might just buy a working/used newer Tube Flascreen with HD for another couple hundred dollars. If there was a newer 2003+ 32 or 36" Sony that has a good track record I would love to hear suggestions. I don' trust flat panels, way too mny horror stories, and for every 1 i hear about there's probably 10-20 more.I'll give them another 5 years or so to get their acts together.
On the other had, if i do decide to get my 32" wega fixed i will post the results and the exact pt numbers of the pts used i the repair. Your problem is exactly the same as mine, to the letter. I'm a mechanic by trade, but i have a good feeling they're not going to give me correct pt # until i have payed them to fix it. Or else i'd order the part and install it myself.
Good Luck,
Aaron
Jan 24, 2009 | Sony Televison & Video
My Wii stopped playing some games.
Check the system menu for any system updates.
Jan 01, 2009 | Nintendo Wii Console
Alesis m-eq 230 stereo equalizer will cut out after 1 hr
Your internal circutry is failing... it sounds like its happening after it gets warm, which may cause an old/cheap part (or parts, like capacitors) to fail inside. think about how long have you had these items and how much use they have had.  As always, thanks for using fixya
Dec 27, 2008 | Audio Players & Recorders
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
