Question about Technics Audio Players & Recorders
My Technics SL-B3 turntable did not turn off after playing a record. I've tried turning it off with the on/off switch with no results
SOURCE: purchased technics sl-bd20d what else do i need just to play records ?
well the mixer is optimal way if you are planning to buy another one sometime but if you are to have only one then you need a corrector which changes the signal (preamp)
just ask for a corrector and say your problem in any tech-shop they will help you..
Posted on Dec 18, 2007
SOURCE: Using Technics SL-B2
check the antiskating. then i don't know.. maybe the tonearm has to be calibrate
Posted on Feb 24, 2008
  • 518 Answers
SOURCE: Cueing Problems on Technics SL-1300MK2
Usually the damping fluid is to let the tone arm lower slowly, lifting is usually a mechanical link. Read THIS.
Hope that helps...
Posted on Apr 01, 2008
  • 7 Answers
SOURCE: How to connect turntable Technics
Most recievers should have Phono Jacks labled on the back. That is where my Turntable an (MCS made by Technics but was sold under the J. C. Penneys name) connects on my JVC. I have 2 JVC 's One is old (1972) and one is new. Both of them have Phono jacks. Phono stands for Phonograph. This is an old term for turntables. The jacks should accept RCA patch cords. Good luck.
Posted on Apr 21, 2008
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
for about $16.
Paul H.
Posted on May 21, 2008
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Technics sl-b35 shut off not working. What should I look at? Record play, arm returns, but will not shut off.
This could be a mechanical switch that is stuck in play mode. You might have to take the bottom off the deck to see what is happening inside.
Feb 08, 2015 | Technics Audio Players & Recorders
Technics sl dz 1200 no vinyl play
is anybody have solution for this? i have the same prob...
Apr 11, 2012 | Panasonic Technics SL-DZ1200 Turntable
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Audio Players & Recorders
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Techics sl-1210s m3 turntable spins back on itself
You have a fault on the quartz-lock speed control electronics. It may be a simple fix, it may be not.
It will require specialist investigation. A Technics dealer should be able to advise you, and arrange shipping back to Technics for repair if you decide that is the best thing to do.
Jan 15, 2009 | Technics SL-1210M5G Turntable
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
388 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
