SOURCE: Suddenly quit working
have you tried useing a cd/dvd cleaner disc sounds like the laser is dirty
Looks like the lens of the player is dirty or damaged. Try a lens cleaner CD first.
http://www.buy.com/prod/maxell-cd-340-cd-lens-cleaner-lens-cleaner/q/loc/111/90049765.html
If it doesn't work then you will have to get the lens replaced. Since the Player is still under warranty use while you still can..
SOURCE: HD-A3 Movies Don't Play Video, but Menus are fine?
Might be a resolution issue, the menus are most likely in 480, while the video might be in a resolution not supported by your tv. Try changing the resolution and see what happens.
SOURCE: My Oppo DVD player suddenly froze in mid-play, and
clean the lens with a dvd/cd lens cleaner (walmart, radio shack, etc.). or if you're feeling adventurous, remove the top, remove the dvd shuttle cover, and clean the lens with a q-tip dipped in rubbing alcohol. wip it off gently ad blow it dry with your mouth (as opposed to a hair dryer). the alcohol will evaporate. put it together and try it out. if it still doesn't read, you may need to replace the optical pickup (lens and motor).
SOURCE: suddenly it won't finish loading a disc. and even
It is possible that the detect sensors are malfunctioning result in the false trigger of the input detector. So in the first place open the front loading section and clean up the CD take up section. Notice the optocoupler sensors which are the cd detect sensors that could be the culprit in this case. Use a multimeter to check for action on the sensor by blocking and confirming for changes in voltage. If so replace the unit. If not you must also check the mechanism for possible misalingment. remove carefully the mechanism and reset after cleaning. Get help if you are not familiar but be very delicate to do this job if inexperienced. Hope you try with care. Good day
