Question about RCA Universal Remote Control
Help need help find a t.v code for a broksonic t.v
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): help - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 Setup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
I need sentry remote code for broksonic flat tv/
I don't see Broksonic listed but since your Sentry remote probably is universal, you can do a code search for something that will handle some, or all, functions. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
May 29, 2016 | Sentry Televison & Video
Broksonic codes
Omega Universal remote codes for BROKSONIC 147 135 250 257 310 394.
Philips Universal remote codes for Broksonic TVs: 0316 0115 0626 0327 0632 0041.
RCA universal remote code for Broksonic TVs: 1000 1004 1239 1246 \
Refrence the manual to the universal remote you are using.
Oct 20, 2013 | Televison & Video
I need a code for my universal remote control to work on a broksonic tv
These are the setup codes for Broksonic TV with GE universal remote control > 0147 0135 0250 0257 0310 0394
Sep 21, 2012 | Broksonic Televison & Video
Remote code for broksonic 19"
Try 136 or 147. These are standard Broksonic codes.
May 18, 2011 | Broksonic CTVG-4563CTC TV
TV remote control code for Broksonic TV's
hi! i have here a couple of codes for your tv, just try them 1114, 1121, 1382, 1383, 1484, hope this helps! goodluck!!!!
Mar 28, 2010 | Broksonic CTVG-5463GVC 19" TV
Have a remote g e and don t have the codes fore the t v
Hi
Universal remotes can use 3, 4 or even 5 digits in these codes. Ideally you need to specify the exact remote make and model of the remote for me to answer this question.
However - I have a number of 3 and 4 digit codes that are associated with Broksonic TVs.
If your remote uses 4 digit codes you will need to go through each of these until you get one that works.
Broksonic TVs commonly use these;
1114, 1121, 1382, 1383, 0147, 0135, 0250, 0257, 0310, 0394, 2053, 2072, 2284
These are the 3 digit codes
236, 463, 003, 180, 277.
Hope this helps. Please do rate my answer. Thanks.
Sep 07, 2009 | Broksonic CTVG-5463GVC 19" TV
I have dish tv need codes to broksonic model# CTSGT-9369CTTC TV ? SO THAT MY ON/OFF AND VOLUME WILL WORK???
can someone tell me what the pass code is for a Broksonic 19in TV/VCR COMBO model no. ctsgt-9369ctt
Jun 09, 2009 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
Need TV codes for using the comcast DTA remote
try these codes for broksonic 10236,10463,11911,11938, 10030,11935,11929
Apr 25, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
NEED TV CODES FOR BROKSONIC TV PLEASE HELP!!!
Have an RCU6000, and a Broksonic TV, need the codes to re-set.
Sep 10, 2008 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
