Question about Electrolux Washing Machines
Electrolux Front load Washer EWF880. The End light is flashing 2 which according to the manual the water is not drained. The washing machine seems to be washing but t is not rinsig and spinning very well. With this model is it very difficult to tell if it is washing or spinning as the function light comes on and it does not say wash or rinse. I can't identify where the machine is going wrong ie if it is the rinse or spin cycle.
  • 262 Answers
SOURCE: smoke from washing machine
Posted on Dec 11, 2007
  • 1847 Answers
SOURCE: Simpson Esprit 750 Washing Machine.
the control panel has gone bad needs replacement.
Posted on Jul 15, 2008
  • 30 Answers
SOURCE: my washing machine wont drain the water
Sounds like a blocked pump.The pump could be burnt out.
Posted on Aug 03, 2008
  • 3463 Answers
SOURCE: Will not run wash properly
The sensor you are referring to could posslbly be the water level switch which controlls the level of water,and also. is a factor as to wether the washer will spin or not, it also is part of the heater circuit, so it has numerous functions.
I t can be found at the top right front of the washer, and is about 3" in diameter, and has a thin plastic tube going to it.
it could be sticking, there is no sure fire way of testing it properly, but you could try tapping it and blowing down the tube, it may solve the prob.
Hope this helps.
Plz rate my solution.
Posted on Jan 04, 2009
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
Why is my eiflw55hiwo electrolux front load washer not properly draining the water at the end of the wash cycle?
hmm sounds like as if any water sensors arent working as they should inside the washing machine's basket or the diagnostic board isnt getting the right info from its sensors in the washing machine's wash tub
Aug 22, 2017 | Electrolux Washing Machines
Electrolux washer -dryer water not going into machine
Firstly we will need some more info. Does anything happen when you press start? Can you do a drain only? A spin only? Any countdowns, display info or flashing lights? Have you got hot and cold water connections and have you tried both settings?
If when you start the washer and everything is in place for your washer to fill and no water enters then it is the solenoid valve (water inlet valve) On a front load washer remove the top cover and you will see it clearly at the rear. They are fairly cheap, also check that the filters in the hose connection of the valve are clear.
Feb 05, 2014 | Electrolux Washing Machines
All lights flashing
Possible that the main controller board has hung up or there is a memory fault. Remove power to the washer for some hours and try. If you notice any moisture within use a dryer to clear, You need to remove the cover and get access to the main board.
Also check and drain filters, if clogged the function will not end and it can show this symptom.
Finally check water flow and door switch connectivity.
Sep 27, 2013 | Electrolux EW1000i Front Load Washer
My Electrolux front load washer does not fill with water in the rise cycle and beeps and displays "draining, no water"
If this is a brand new product, I suggest that you MUST call for warranty assistance from their depot.
This can be related to failure or error of the controller, fault in the inlet or water level sensor which must be done free of cost.
Feb 12, 2013 | Electrolux EIFLW50LIW 4.2 Cu. Ft. Front...
Electrolux washer door won't open
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
Our front load kenmore washer is not draining properly at the end of the wash cycle. At the end of the wash cycle it sounds like it is trying to drain but it does not even spin. Then it seems to run water...
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Aug 31, 2011 | Kenmore Washing Machines
Washer making loud noise willnot spin cycle or drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Aug 10, 2011 | Electrolux AWF 1435 Front Load Washer
The washing machine Electrolux AURUM16 Problem
Make sure the water is drained or the door wont open
Sep 08, 2017 | Electrolux AWF1220 Front Load Washer
My AWG 320/2 doesn't seem to be draining away the water properly at the end of a cycle. Any idea what the problem might be.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
Jan 23, 2011 | Whirlpool AWG320 Front Load Washer / Dryer
Do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
Aug 26, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Washing Machines Logo
322 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
