Question about Packard Bell iMedia 6826 (P481000502) PC Desktop
Tattoo hdd can i get a floppy to retattoo hdd ? If i can where do i get it from ? Imedia tower lable says its a M82400NDRW but that does not mean much to me. this was pre-installed softwear, i have master cd 1-2 but this tattoo is holding me up from getting PB softwear to re-install. I have XP disk but want to return system back to the way it was perchased with all the softwear installed from master cds. Can someone send me info on this or where to get this partion boot floppy from please. have had no luck with this system, as PB dont supply this floppy.
  • 66 Answers
The only way to get either the cpc dmi or the hdd dmi tattoo disk is from hp or like me be a sert hp tech, samlong.delta82nd@gmail.com sending me an email and I can either mail you the disk or sending you the iso file.
Posted on May 15, 2010
Intermittent floppy disk drive for Husqvarna Viking Designer 1
These 3.5-inch floppy disk drives are never produced by the manufacturer of the device, but by one of a few floppy disk drive manufacturers (usually Sony) and as such, should your disk drive start to fail, you may be able to disassemble the case of the Viking Designer 1, remove the floppy drive, and insert another standard floppy salvaged from a tower-type PC, thus fixing the problem.
Since 3.5-in. floppy drives are becoming more and more scarce in modern computers (in favor of CD-RW drives) you may have a obsolete tower computer (remember Windows 98?) in your basement (or your friend's basement/yard sale/flea market/www.Craigslist.org/www.eBay.com) that could supply a useable FDD (floppy disk drive).
Oct 04, 2011 | Husqvarna Designer I
While i am tring to repair 2003 standard server on IBM 3400 Tower server i am facing a issue that hdd not found
Windows not see the disk because they are connected through a raid controller.
When you start the recovery windows you have to offer the installer the driver for raid. Installer wait new driver only 5 seconds.
During this time you must press "F3" and point driver on floppy.
Jun 16, 2011 | IBM x3400 Server
I have a Packard Bell iMedia SL 9553, The odyssey Boot Floppy has been lost, Any Way I could get a copy to restore the computer using the Master Discs I have?
YES YOU WOULD BE ABLE TO Call packard bell and show them proof of purchaase and get them sent out to you now packard bell was bought out by hewit packard and there number is or you could go to this website and get any driver you would need http://list.driverguide.com/list/company788/
Jan 14, 2011 | Packard Bell iMedia SL 9553 (P660401806)...
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Aug 04, 2010 | Maxtor Hard Drive
Tattoo hidden partion
Hi there, the disks will only work if you have the drive that came with the laptop/dekstop
You will need to get hold of an OEM version of Windows XP Home - you can reinstall from scratch, but will need to install the drives etc for your computer seperately,
You will use the licence key that was proved with your computer.
That will sort it out.
Regards
Chris
Jul 21, 2008 | Computers & Internet
Boot record for floppy drive
Yes. Most new computers today don't come with a floppy drive as they are pretty much obsolete. If you need a floppy drive because you have a bunch of floppies around with important stuff on them, you can purchase an external usb floppy drive for around $20 or so.
Jul 03, 2008 | E-Machines etower 500ix PC Desktop
Regarding the hdd size and bios update
The issue with your board is that it can't see drives above a certain size. This does require a BIOS update, usually involving a floppy drive. Look in your BIOS - there may be an option for you to be able to boot from other devices. Check to see if "USB Floppy" is one, as it means you could potentially use an external floppy drive, which are cheap at most electronics stores.
Alternatively, if you or a friend has another computer, you might try borrowing a floppy drive to do the update.
Alternatively, you could go to the manufacturer's website and check the information they have for your particular board. Many now let you download an executable file with the recent BIOS updates that you can use without having to use a floppy drive. Some also have methods that you can burn to a CD.
Mar 14, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Cant take apart packard bell imedia to install pci card
when disassembling server chasis, you will have to release the front panel first, only then you can remove the side panel
Jan 03, 2008 | Packard Bell (090317) Modem
Packard Bell iMedia 6826 (P481000502) PC Desktop Logo
289 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
