Question about Sony Cameras
When i turn the camera and try to take a picture it tells me to turn the power off and on again then it beeps. i have tried many times to power on and off but it still shows the same message.
I have the same problem
what should i do???
Posted on Dec 26, 2008
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Every time I try to turn the camera on it beeps and the screen says access... then says turn the power off then on again. Why?
This problem is related to optical zoom motor,The part detail is given below:
Part No. Description
A-1231-924-A LSV-1160A
Replace the said part number and your camera work fine again.
Thanks for using fixya.
Jul 29, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
When I turn my Sony DSC-W55 on it will say Access on the lens. The lens will come out and retract a couple times. It will beep and then say Turn the power off and on again. I have tried replacing the...
I had the same problem with the lens, just pull the lens gently until u hear a small click sound, it will be like new again. just tried it and it really works
Apr 10, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
When the camera is turned on, it beeps and tells me to turn the
When the lens will not retract or camera is not functional (no picture on display, and does not shoot, and eventually bleeps) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Apr 08, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
What is wrong with my digi cam?
Try this:
Turn on the camera in another mode.
Go to the menu.
Find the option to reset ALL.
This may fix this problem, because you can the get the camera working.
If there is a lens problem, this same message may come up. Check to make sure your lens is working correctly.
Jul 19, 2008 | Cameras
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
Cameras Logo
73 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
