Question about Dell Inspiron 6000 Notebook
Dell Inspiron 6000: even when I plugged in, it still appears to be running on battery
Several weeks ago, I got error message indicating that my battery needs replacement, Although I didn't replace the battery, I used my laptop always plugged in so that I don't have to worry about the battery. Now, even when I plug the laptop to the outlet, it still indicates it is running on battery. After a few minutes of running it just shuts off (as if the battery is completely drained). My question is if purchasing a new batter will solve the problem?
    Genius:
  • 2,028 Answers
Possibly. To tell if it's just a battery issue, take the battery out and try starting it on AC only. If your machine starts and works properly then the battery is the only problem and replacement will cure it. If it won't start or doesn't work properly, then I'm afraid the failing battery has shorted the power managment chip on the motherboard. So, give it a try, and let me know. If you have any other questions feel free to ask.
Posted on Jul 22, 2008
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
New aftermarket Inspiron 6000 battery will not power the Laptop
I would say that the power management portion of the system board is probably faulty if it behaves the same with both the factory battery and the aftermarket.
Many systems have the charge controller and battery interface on a separate board but unfortunately on the Inspiron 6000 it's integrated.
FYI, Here's a copy of the service manual for that system: http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
Jan 21, 2010 | Dell Inspiron 6000 Notebook
Inspiron Battery Light Flashing Orange
Battery.
Dell has a chip internal to the battery programed to shut down after a certain number of charge cycles. This means every time you plug the laptop in with the battery installed. When it reaches this determined number the battery effectively shuts down, even though technically it's still good. There have been loads of complaints on the net toward Dell over this issue. I have myself experience this. Battery good one day, powered down, went home, powered up... only to receive the deadly flashing light. Only cure is to replace battery. Several hacks trying to get around this but they're all horrible. Bad Dell - bad, bad Dell!
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 not charging
suspected faulty battery. replace the battery.
May 28, 2009 | Dell Inspiron 1501 Notebook
Sir as i m installing xp2 pack as os within a week i m getting a system 32 error nd a blue screen error where the system gets restarted and a message appears stating the ''THE WINDOWS DELAY WRITE...
run a hard disk self test from the bios.....if it fails then you have to replace your hdd and if it passes then reinstall the OS from another disc
Mar 17, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 error msgs: page_fault_in_non_paged_area and k
When u power up the computer pressF8 key the enter in safe mode.
if u enter then type in run "chkdsk /r"
then "y"
then restart the computer.
if u not enter in safe mode then u need recovery disk .and go to recovery console.boot with recovery disk ten inter in recovery console then type in command propmt "chkdsk /r"
then it recovers bad sectors then check .if u still get error then u have to repair xp.
Jan 29, 2009 | Dell Inspiron 6000 Notebook
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
52 people viewed this question
Alun Cox
