Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark 5070 printer
Refilled #28 and #29 , black and color cartridges with ink. Printer says replacement required? doesn't print. do i need to get new cartridges?
    Guru:
  • 1,049 Answers
Hard to tell...There are other issues which could contribute related to the printer itself, etc.
But I will say in my experience often refill kits for ink cartridges don't work if you allow them the cartridge to run bone dry. Maybe the internal components become hard and won't re saturate with new ink, not sure. If new cartridges work; and the refills don't I'd say there may be a problem with them.
Posted on Jul 23, 2008
Is it true that both my new Lexmark Prevail Pro 705 print heads quit printing in color is because I didn't use Lexmark OEM ink cartridges?
Some Lexmark cartridges have an RF chip mounted underneath the label on top. Most of these are set to self destruct on first use to prevent refilling. You probably need to risk the cost of a new cartridge to find out if it is a cartridge problem or a printer problem. Unfortunately you should not take out a cartridge or replace one while the machine is powered. The system also frequently registers an serial number on the cartridge and stores it to prevent "hot swapping" cartridges
Dec 11, 2017 | Lexmark Prevail Pro705 Wireless AIO...
Colourcartridgenotprinting
Just make sure you are inserting genuine Lexmark cartridges. Lexmark does not recommend the use of refilled, remanufactured or clone cartridges, you might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try cleaning the cartridge nozzles using the Lexmark software installed on your computer instead:
1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark 2600 Series folder.4. Select Lexmark Solution Center.5. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean it from dirt and possible clogs.
If that doesn't help but you're using genuine Lexmark supplies, please contact Lexmark Technical Support for additional assistance, otherwise, please replace your color cartridge with a genuine one.
Dec 12, 2011 | Lexmark X2670 All-In-One Printer
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
Dec 24, 2009 | Lexmark X4650 InkJet Printer
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
Ink Cartrdige Won't Print
it is because the cartridges are non refillable..... they have a memory chip in them and can not be refilled except by lexmark thru their recycle center
Mar 22, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Printer not working!
Usually black is provided by the black cartridge only. You might be able to setup the printer through the control panel using black and white printing until the color cartridge is replaced. That might turn the color cartridge off allowing you to print.
Jul 27, 2008 | Lexmark Z1300 InkJet Photo Printer
Color ink cartridge
Yes you need to have both carts in the printer
Jun 02, 2008 | Lexmark X2500 All-In-One Printer
X5470 Lexmark printer
Lexmark and Dell use a sensor in the cartridge to sense a low ink level. Once the sensor has been activated, you cannot reset it. The printer should work fine except for the fact that you'll have to override the "low ink" message on your computer.
Manufacurers don't make money on printer hardware. All the money is made from ink replacement, so they make it as difficult as possible to use anything other than the stuff you buy from them. Some (HP) put in chips for an "expiration" of the ink/toner. Go beyond the expiration date, the thing won't work.
May 13, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X4270 All-In-One InkJet Printer Logo
98 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
