Question about Intel Motherboard
Dual monitors Had my toshiba notebook running with my viewsonic lcd monitor now lcd monitor won't work. The only thing I can think of is it happened after real player updated.I don't know how I got on the motherboard trouble shooting... sorry
  • joylynn Jul 26, 2008
    thanks for your help
  • 125 Answers
Most laptops have a function key to set which monitor is active. By toggling this key, you switch between laptop screen, external screen, and both.
On the keyboard, the key is usually Fn pushed together with one of the function keys that has a monitor logo above it.
Posted on Jul 22, 2008
I had my ViewSonic VX1935M-3 Lcd Monitor shut off for 2 years, I tried turning it on now and the power button flashes blue but the screen stays black. How do I fix this?
The absolute worst thing you can do with a piece of electronic equipment is to let it set. If as you stated the laptop registered it OK then it could be that it has lost it's memory and needs the drivers updated. The laptop will only tell you that it is connected it does not run a diagnosis on it. If you have the disc for the drivers try running it while hooked to the monitor. Other than that you may have internal problems with the monitor. It could be the inverters. logic controls and numerous other things that just seem to die of neglect I guess you could say. I have found about every kind of problem with TV's and Computers that have been mothballed for a length of time. I would think it is the drivers though. If you do not have the disc go on line to the Mfg. of the monitor and enter the model # etc. and try to find a download for the drivers. Most Mfg. have free downloads of the drivers for their equipment. Hope this gets it going and if I can be of any other assistance please feel free to contact me.
Col. Dana Gillespie
Mar 24, 2014 | ViewSonic VX1935wm LCD Monitor
My viewsonic vx1940w monitor won't turn on. There's no lights or anything. The outlet it's plugged into is working because I tried another device in the same outlet. My settings didn't...
I had two ViewSonic's that did the same thing right around 2 year as well. They worked really well for me and then just died.
I found out the first one had a faulty power cord, and the second one just wouldn't turn on at all.
I think there's a good chance that your monitor bit the big one just based on my experience with the brand. I would recommend taking it in to your local computer repair shop and let them take a look at it. If it is 2 years old then it is probably out of the manufacturer's warranty unfortunately. I hope this helps answer your question :(
Thanks for using FixYa.
Aug 27, 2011 | ViewSonic VX1940w LCD Monitor
I have a dual monitor set up. I had a Dell monitor as the primary with a samtron secondary. Today I made a Viewsonic monitor the primary and moved the Dell to the secondary. However now the Dell switches...
You may need to check some configuration of dual monitors.
Did you change the graphic card for the primary monitor? There could be a support between that graphic card and the monitor.
Did you check the power settings about monitor and disable any power saving plans?
Dec 05, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
VX924 (Silver, Black) 19" LCD Monitor: monitor has suddenly gone white...
My VX924 did the same thing but now displays nothing and power switch light just blinks. According to an answer listed on previous page, it may have bad capacitors. I may have to take a look at them. Viewsonic repair facility examination of this monitor runs $70.
May 17, 2010 | ViewSonic VX924 19" LCD Monitor
My company has 2 viewsonic vx2235wm monitors that have recently died on us. First my co-workers monitor went black and the blue light turned orange. Then we turned it off and back on it would stay on for...
More than likely this is a driver problem. Many people are having this issue with the new driver that has been made available for this monitor. I have two of these monitors in a dual configuration and had the same problem. You will need to download the old driver or just delete the new one that downloaded and it should fix itself.
Good Luck,
Rob Mixon
Jun 05, 2009 | ViewSonic VX2235wm LCD Monitor
Toshiba Satellite Laptop refuses to allow Dual Monitors
I have an A105 set up on dual screens, and it works great. As I recall, you have to do the dual screen setup in the control panel, display, settings.
Mar 17, 2009 | Toshiba Satellite A105-S4074 Notebook
Installing Ubuntu after vista install gives "out of range"
this is great guide to set up a dual boot option on your on pc
Mar 16, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Blank (dark) notebook screen after hooking up digital ext monitor
I notice a difference in the setup of the two monitors, have you installed the correct driver for the new screen?
Try F8 on startup to get into safe mode, this should allow you to use the default VGA screen, and to reset the correct monitor drivers.
Dec 08, 2008 | Sony VAIO VGN-A790 Notebook
About a problem in my viewsonic monitor
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
Intel Motherboard Logo
299 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
