Question about Teac DV-3000 DVD Player
Region DVD says wrong region. will not play region 1 How do I set Teac DV 3510 DVD Player Region Free?
  • Anonymous Mar 29, 2014
    putting d v d into teac t v and then how to play d v d
  • 163 Answers
Probably can't, they are encoded for a reason. If you have a DVD drive on your computer MOST video players will play them.I use Nero and haven't had any trouble.
MM85
Posted on Jul 22, 2008
Teac lev2494fhd
MAKE Please this steps and fix it. Merry Christmas.
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Dec 17, 2013 | Teac DV-3000 DVD Player
What is the multi region unlock code
SEE THIS .GOD BLESS YOU
Manufacturers of DVDs and DVD players install codes that only allow us to play DVDs that are manufactured for our region. (For example, the U.S. and Canada are region 1, while China is region 6.) To make your DVD player region-free, you'll need to find the unlock codes that will allow it to play DVDs from all over the world. Below are some steps to help make your DVD player region-free.
Read more: How to Make Your DVD Player Region Free ' eHow.com http://www.ehow.com/how_2036609_dvd-player-region.html#ixzz285JT4y65
Oct 01, 2012 | Teac DV-H500 DVD Player
DVD's wont play - says wrong region but they are compatible
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
Nov 23, 2009 | HP Pavilion dv9000z Notebook
Says wrong region with some dvd's
Check the owner's manual to see what region your dvd player is for. What ever that region is is the only region it will play.
Example: If you have a region 1 dvd player and a region 4 dvd, it will not play on that player. The regions must match. The dvd usually has the region it is for listed on the back of the dvd case near the bottom.
Also, Any dvd's that are Region 0 or are labelled "Region Free" will play on any player.
Oct 03, 2009 | Sharp DV-SL1500W DVD Player
I want to unlock the regions on my TEAC DV2800
  1. Turn on
  2. Open tray
  3. Press 2, 1, 6, 8 then ENTER using the remote control
  4. press 0 then turn the player off.
Jul 10, 2009 | Teac Televison & Video
I have this exact problem!
I found a couple of region 1 DVDs and tested them in the player they worked so that's the solution?!
Jun 19, 2009 | Teac DV-3000 DVD Player
How do I set the player to multi region for a Sharp DV-SL1500W ?
try this
- switch on DVD player
- press eject (tray open)
- press stop
- press 734466
select 0 on OSD for region free
Mar 18, 2009 | Sharp DV-SL1500W DVD Player
Region Unlock TEAC PL-D3200
Multizone code for Teac PL-D3200 Here is the procedure to unlock your Teac PL-D3200 to play all zones of DVD's.
Using your remote control:
1. Switch power on 2. Open the dvd tray (leave it open with no dvd in it) 3. Press "stop" 4. Press "734466" 5. Use cursor to scroll up or down until it says "Region 0" 6. Press "OK/Enter" 7. Switch power off 8. Switch power on
It will now play all region DVD's! :-)
Nov 28, 2008 | Teac DV-H500 DVD Player
Region
Follow these steps to make your DV3500 a region free player. With the power to the DVD player on...
OPEN TRAY
PRESS SETUP
TYPE IN NUMBER SEQUENCE 9 3 0 1 0
PRESS STEP
PRESS SHUFFLE
PRESS NEXT
CLOSE TRAY
POWER OFF
POWER ON
The DVD player should then be region free.
Best of luck!
Feb 21, 2008 | Teac DV-3500 DVD Player
Unlock procedure for Regions
1. Press Open/Close on remote control. DVD tray opens. 2. Press the following buttons in sequence: 2, 8, 1, 2. 3. TV displays "Region 2" 4. Press the Enter button on the remote until code changes to 9 5. Press the Open/Close on the remote. DVD tray closes. 6. Press Power on the remote control. Now code free...
Feb 19, 2008 | Televison & Video
Teac DV-3000 DVD Player Logo
169 people viewed this question
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
