Question about Nova Development Photo Explosion Deluxe Version 3
HELP ok i have done a slide show and ,ore things and now im done with my work. so how do i have it on a cd to send it to someone?
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Do you have the file on your computer? just send it to somebody
Posted on Jul 22, 2008
  • sapir huberman
    sapir huberman Jul 22, 2008
    do you have outlook?
How do i send more then 1 pic at a time to a contact
go to new message then press the menu button select attach the menu comes up select slide show. now u decide how many pics to send. remember u have a 300kb limit. say you wanna send 2 pics hit the add slide now you have 2 slides. now go to the 1st slide it has 2 arrows, preview, add pic, and remove slide. now hit add pic select your pic then hit the right arrow above the preview button. now select your 2nd pic now u can preview or press done. its ready to send you can preview by pushing the play button. I hope this helps !!
We Are Here To Help !!
Aug 25, 2017 | Cell Phones
DeWalt D51823 nailer leaks air and shoots continusously
Common problem with dewalt due to vinyl orings. Simple tests to determine if trigger valve may work before re-installing. With trigger valve in hand, depress the trigger pin and hold. The bottom of the inner spool is visable in the opposite side from trigger pin and should move inward slightly with little effort when you push it (spool should have almost no movement inward before making contact with body of valve ). If the spool moves inward 1/16 to 1/8 inch, most likely the oring is too worn and not making contact with body of valve (when under pressure, this spool is held against body of valve (closed), and will open when pin is depressed (firing pin pushes on the spring and spring pushes open the valve) ). Next take valve apart and pull out the spool (spool should be difficult to remove from lower body of valve). With spool in hand push upper part of spool into the cap, should fit snuggly. trigger pin has two orings. The upper oring should fit snuggly into cap and lower oring snuggly into spool. The two orings on the pin are made of vinyl and fail. Notice that the spool has a small hole at the bottom. If the pin oring s bad air will leak past pin. Replace with 2mmx1.5mm black oring. After replacing the two pin orings, make sure the pin fits snuggle in the cap and spool, if not , replace the whold valve. The spring is usually good, but if rusty, replace the whole valve unless you happen to have the exact spring in good condition. The two outer orings on the body of the valve do not have to be replaced unless cut. Good luck
Dec 23, 2012 | Air Tools & Compressors
When I send and IM it does not show on the screen after I hit send and when I am alerted that someone has sent me an Im I cant see it at all. Its like it was never recieved or sent!!! Please help!
The first thing to check is to make sure you have scripting enabled in Internet Explorer. Internet Explorer is integrated into Yahoo Messenger so things that go wrong with IE can affect Yahoo Messenger. Here is the yahoo help page about that:
2) In the Start Menu click on Run. Type, without the quotes, "regsvr32 jscript.dll" and then click OK. Next, repeat the process but this time type in the Run box "regsvr32 vbscript.dll" and click OK. Please note, if you are using Windows Vista temporarily disable the User Account Control (UAC). You can easily turn it back on. On the Control Panel (Category View) choose User Accounts and Family Safety, next choose User Accounts, and then click Turn User Account Control on or off.
3) If the above does not fix your problem and you are using Windows XP, you can update your Windows Script to version 5.7. In my experience helping others, this is the step that has helped the most people. Exit all browser windows and chat programs including Yahoo Messenger before installing. run registry cleaner reginout cleaner to easily fix it
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Yahoo Messenger
I've created a slide show in Slide Show Expressions and saved it as a project to my hard drive. Now I want to burn a CD. Do I click on "produce" at the edit mode of SSE, to burn the CD. Then...
What you need is a CD burning software like Nero to simplify things or you can just right click the project file and from the pop up menu select "Send to" and then select your CD writer drive. If you do not have a "CD writer" device in your computer you will not be able to burn the CD.
Good Luck!
Mar 10, 2011 | Computers & Internet
Paslode PowerMaster Plus F350S drive pin won't reset all the way back up? Any step by step instruction fix it or clean it up?
Most common cause for driver not returning is a worn or missing blade seal which is a washer with a slot found under lower bumper. Remove head and cylinder. Check that driver is not bent and slides snuggly thru slot in washer. If washer seems ok then check for missing check seal oring found at lower end of cylinder. Clean the holes under check seal. Finally check oring at driver piston. Oring should just hold piston in place without sliding down cylinder. The driver should not be too tight nor too loose. Re-assemble using silicone paste on all orings (small tube of silicone available at Lowes plumbing department, used to lube faucet orings). Good luck and post again if you have other questions.
Jun 04, 2010 | NRS Paslode 501000 Powermaster Plus...
Small coolant leak from what looks like a metal cylinder in the middle of the V
The silver looking tube with the clips between the cylinder heads is a coolant tube. There are o-rings on each end. Remove the clips, then slide the tube towards one cylinder, the oring will be exposed and you will have enough clearance to remove and install the oring. Then slide the tube back into the opposite cylinder to expose the other oring. After replacing then center the tube , reinstall the clips and refill the cooling system. I use a soapy solution to lube the ring so they slide easy and not roll.
Apr 21, 2010 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
The 'safely remove hardware' keeps removing my cd/dvd drive.
OK - hold on.
Before reinstalling the OS here is a quick somehting you can try:
Next time the message shows up. Remove the CD/DVD from the laptop. Give it some time without it and see what it does. After awhile, slide the CD/DVD back in. This may fix it.
Apr 07, 2009 | IBM ThinkPad R52 Notebook
hmmmmmmmmmm try alpine support. Audio Products Technical Support
(Alpine Electronics of America, Inc.)
(800) TECH-101 (1-800-832-4101) they should definitely help you out. thats definitely a problem with the decks with the slide out fronts.
Jun 12, 2008 | Alpine CDA-7892 CD Player
Easy cd & dvd
ya bad program u should try to go to ther website download ther latse fixes patch for ther program ok if not use download nero 8 or 7 ok way coooler easy to make slide shows movies with music also windows phtoo story does it also free to download
Jan 26, 2008 | Roxio Easy CD & DVD Creator 6...
D Drive will not work.
try booting your pc using a bootable cd (in the same drive). If it boots, try accessing the directories in the CD. If ok, your CD drive should be OK. Otherwise get your CD Drive repaired/replaced. You can also try a CD drive cleaner if nothing else works...
Sep 22, 2007 | Computers & Internet
Nova Development Photo Explosion Deluxe Version 3 Logo
32 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
