Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Printing degrades When I do a copy or send a document to the printer (color or only black) it will start to print but by the end of the first page it starts to fade and prints nothing. Even though it sounds like it's printing it spits out blank pages. If I go to Maintenance and do a Head cleaning it works fine after that. But if the printer sits idles for 20 or more minutes it fails with the same symptoms and I need to clean the heads again. I've replaced all ink cartidges hoping this might be the cure but the problem continues. I really like the printer and do not want to discard it if there's an easy and relatively inexpensive fix available. Any help is greatly appreciated.
  • 125 Answers
I have 3 MP780s' and I have a similar problem. I'm guessing that you are printing majority heavily colored pictures. We found out the problem when we used refilled cartridges. We'd print 1-4 pages before we have a problem w/ 1 color not coming out. We would switch to OEM cartridges and the problem disappears. I'm guessing that you don't have this problem when you are printing text based items or doing slow printing. If so then that means by setting the print speed slower, there is a chance you will minimize the problem.(This is just an alternative.) If you have this problem w/ OEM or refilled cartridge, I suggest you to go to a pharmacy and get a small 10 syringe that has a screw-in lock for the needle. You won't need needles just the syringe. The diameter of the syringe should match the BCI-3e cartridges opening (except for the black). Put the syringe there and **** out some ink. Maybe 0.5-2 ml. Most likely you will get bubbles and I think this might be what is called a vapor lock. I've never seen this happen to OEM cartridges but I've seen them happen on refilled cartridges. But hey, maybe there's a first time. I'm assuming that your OEM cartridges are more than half full. Let me know if this helps.
Just to clarify, when you od the nozzle cleaning, do you do a print test after. From the print out you can see which color is clogged up. Work on that cartridge.
Posted on Jul 22, 2008
How to remove printhead
Alignment shows black & streaky, only covers 3/4's of a line, color is good. The printer copies a document no problem; but only copies color (no black) from the computer. If the document is black print, I get a blank page. Do not know how to remove printhead
Jun 29, 2013 | Dell V313w AllInOne InkJet Printer
4215 all in one office yet. When making a copy
Sounds like you're having a problem with the automatic document feeder. The scanner is continuing to scan but the paper is not advancing as it should during the first part of the infeed. Check to see if something is inside retarding the path of the scanned document. Or it could be worn rollers in the ADF.
Jul 18, 2011 | HP Officejet 4215 All-in-One Color Photo...
I have a pinnacle Pro 901. How do I print in black & white only?
Hello, try this: Start Menu, > Printers and Faxes> then right-click on your printer. Move the pointer down to 'Printing Preferences' and click the 'Advanced' tab. There you will (should!) see 'print in greyscale' . Select this then click 'Apply' then 'OK' at the bottom of the page.
Dec 01, 2010 | Lexmark X2250 All-In-One InkJet Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
I don't know how to fax
The control panel LCD also provides menus to operate the copy and fax modes independently of a PC. One nice touch: the LCD displays small and large type on the same screen, allowing more information about a print job to show at one time. b.gif 21262659-2-200-dt2.gif
The flash card reader under the control panel means you don't need a PC to print photos.
The MP730, while easy to operate, lacks some of the advanced features you might find on separate printers or faxes. For example, the MP730 can't collate copy jobs. To make more than one collated copy of a multipage document, you have to place the document in the ADF several times. Nor can the MP730 sync fax numbers entered by hand or accessed from within the Windows Address Book (Canon doesn't provide its own fax/address-book software), so you may end up duplicating efforts. Nor does Canon's software create group dials from your address book on your PC or provide a cover sheet. Finally, the MP730 can't forward faxes to another number or hold a fax to send when nighttime low rates kick in, which other multifunctions do.
Still, the MP730 provides plenty of features we do like. Using the menus with the Photo Print mode, you can print a photo contact sheet, pick individual images to print, and set up the printer to copy or print onto high-quality glossy paper. In the Copy mode, menus let you print two reduced originals side by side or print the same image on the same page several times (useful for business cards, name tags, and so on). The fax engine distinguishes voice from fax, sending voice calls to your phone or an answering machine and sending fax calls to the printer or to buffer memory so that you don't have to get a second phone line installed for your fax.
Installing the MP730 software is slow but idiot-proof: You just pop in the CD and follow instructions, which require restarting your PC several times. Canon bundles the MP730 with ScanSoft's OmniPage SE, a lite version of the best optical-character recognition software on the market, and NewSoft's Presto PageManager 6.0, one of the best document-management databases available.
The MultiPass MP730 won't replace top-of-the-line printers and scanners, but its print and scan speeds keep up with other multifunctions' as well as that of most as midrange ink-jet printers and scanners on the market today. In our tests, it printed ordinary text at 6.4 pages per minute and printed CNET's high-resolution test photo in 3.7 minutes. For comparison, the Lexmark X5150 (only $149 but without fax capability or automatic document feeder) prints text at a more common 5.2 pages per minute, and printed our test photo in about 2 minutes. Canon's MP730 scans a page of black in 9.4 seconds and a page of color in 20 seconds; that's seconds faster than the HP PSC 1210. And the Canon makes copies in 18.7 seconds; that's almost twice as fast the HP PSC 1210.
Unfortunately, the MP730 delivers a mixed bag on image quality. When printing, better paper has a big effect. When we printed text on ordinary paper, for instance, it looked grayish instead of black, and a gray shadow haunted the edges of letterforms, while on coated (not glossy) inkjet paper, text popped out in a solid black and looked much cleaner. Our color photo on ordinary paper looked very dotty, had rough transitions between shades, made a blob of detailed areas, printed lines with jagged edges, and mixed inappropriate colors; coated inkjet paper improved detail and let colors appear in the right hues, though much too saturated. And on top-quality glossy paper, textures, shading, and transitions suddenly looked right, and we saw sharp, clear detail.
Grayscale scans on the MP730 when compared with other scans seemed overexposed, losing paler shades of gray along with some detail, while color scans showed accurate colors and fairly good detail despite somewhat grainy textures.
Jan 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My printer will not print any documents, it does print a test page, when I select print the paper is ejected. I have re installed the software.
Try to print a self test page from the printer directly using the below steps....
  1. Make sure the printer is loaded with plain, white paper. Remove any special or colored paper.
  2. Press Setup on the front panel of the product.
  3. Press 1 , to select Print Report , then 5 , to select Self Test .After you have the report printed, check for 4 horizontal color bars in that report, the first color should be the the black one, if the black one is missing, issue seems to be with black cartridge, that may be the reason the printer spits out blank paper, try to replace the black cartridge and then copy if it copies or not.
Sep 26, 2009 | HP PSC 2210 All-In-One InkJet Printer
My printer is printing everything black when using feedtray only
Their should be a Black Copy button and a Color Copy  Button . When wanting to copy a document in color you must choose the color start button.. Good Luck
May 04, 2009 | Dell 962 Photo All-In-One InkJet Printer
Scanned Items or Copies all print in Solid Black
I assume that you mean color images are being produced in black and white. If that's the case, there's a document on the HP web site that shows you what to look for and provides solutions:
Color Image Prints in Black and White
Good luck.
Sep 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Trouble with color printing
Have you tried to print a 'test page?'...
Go to 'Printers and Faxes'. Select right click on your printer and select 'properties' on the Printer properties window, select 'Print Test Page' (button at the bottom of the window.
Let me know what's the reseult.
Mar 11, 2007 | Canon MultiPASS C530 InkJet Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
47 people viewed this question
old marine
old marine
