Question about MTV Games Rock Band for PlayStation 2
Drum pads One of the drum pads on the drums cracked underneath and I was wondering if there are replacement pads.
  • Anonymous Feb 06, 2009
    we just bought rock band and the blue drum pad will not work...is there anything we can do?
    Problem Solver:
  • 5 Answers
I'm not really sure but there might be acsessories for it. But if not you need to buy rock band again.
Posted on Sep 13, 2008
How to repair stainless steel on a dryer drum
For my Frigidaire manufactured Kenmore dryer, the stainless steel drum is part ordinary painted steel (front flange). That flange is part of the suspension for the drum. The flange rides on a nylon wear pad above the door. On both sides of the pad, there is a felt that is glued to the dryer front panel to act as a seal. What happens is that the paint on the ordinary steel flange rubs through and rusts, staining clothes during the drying cycle. I have to replace the nylon pad and felts every few years to combat the rusting issue. The felt and nylong pad assembly is glued to the cabinet flange using heat resistant adhesive.
Feb 25, 2012 | Dryers
Trying to remove the drum off rear wheels to service and replace break pads. wondering if there is something holding it on besides rust. cant get drum loose. is there a set key or anything holding it on?...
once the star wheel adjusted is threaed all the way in the drum should come off
rust will hinder the removal too
swating the drum with a 5 pound hammer lightly will help
the star wheels are right hand threads on the passrnger side and left hand threads on the drivers side
Mar 20, 2011 | 2000 Chevrolet Lumina
How to get drum pads off a 2000 dodge caravan
The pad drums of your 2000 Dodge Grand Caravan can wear with use. Heat buildup in the brakes can glaze, warp or crack the drum. If that happens, replacement of the drum is the only way to fix it. In most cases, you can remove the rear drums, replace them with a new set and leave the existing shoes on the van. Take a minute and inspect the brake shoes thoroughly while you have the drums off the van.
  1. Loosen the lug nuts on the rear of your 2000 Dodge Grand Caravan with a lug wrench. Do not take them off the wheel studs.
  2. Raise the rear of the van with a jack and support it on a set of jack stands. Place the stands under the rear suspension, making sure they are secure. Remove the lug nuts from the wheel studs and pull off the rear wheels.
  3. Check the rear drum where the wheel studs come through for retaining clips. These are used during the manufacturing process; and if they are still on your van, they need to be removed. Pry the clip off the wheel stud with a flat head screwdriver and discard them. Most vehicles will have two clips on each brake drum.
  4. Grasp the brake drum on the outer edges and pull it straight off the wheel studs and brake pads. Discard the old drum and slide the new drum into place, aligning the holes in the drum with the wheel studs. Push the drum in until it seats completely. Repeat the process on the opposite side of the van.
  5. Position the wheel back on the wheel studs and install the lug nuts by hand. Raise the back of the van with a jack and remove the jack stands from under the suspension. Lower the van to the ground and tighten the lug nuts with a lug wrench.
Jan 08, 2011 | 2000 Dodge Caravan
Dryer drum is scraping something and black deposits are turning up on our clothes
Well there are two parts to the drum, there is the bearing in the back and the felt pads in the front which the drum rides on. There is also a belt, but if something is scraping it would not be that. Is sounds as though the cover on the felts has worn off and your getting felt material on your clothes, so those need to be replaced. You need to get the proper felts for your dryer than you need to look for any screws on your dryer casing that will allow you to remove the casing and get to the drum, as the pads are underneath the drum. (Note: Inside the door there may be screws on the underside of the upper deck, and the deck should tilt backward on hinges)
May 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Hi, ive worked with bikes mainly and have replaced drum and disc brakes on them. I am working with a ford bronco 2 1988 and would like to know how to replace the brakes on it. I know the front are disc and...
Not much difference replacing the lines and fluids between disk and drum brakes. Huge difference when replaceing the pads. Never force the drum over the pads with a hammer etc. Make sure to take a picture of the assembly before taking it apart when not firmiliar with something. Adjust the brake tension through the site hole once the drum is over the pads.
When doing the disk brakes, make sure that you do not push in the caliper piston at it's edge. Use a C clamp placed dead center on the piston if required. Don't push it in any more than needed.
Nov 05, 2009 | 1989 Ford Bronco II
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
Yellow drum pad stopped working, only had these for 5 months=(
You need to replace the piezo sensor, you can get them at radio shack really cheap. $2. The same thing happen to me, I pulled the drum pad off and the sensor was totally cracked, I guess from hitting it too hard. Just unsolder old ones and solder new one on.
Aug 21, 2009 | Nintendo Rock Band for Wii
Maytag Dryer MDG9700AWW has split into the metal drum at the seam
I'd say take the 50% off offer. Dryer drums are very thin, and a weld would most likely still make a thump noise every time it passed the drum supports. (two thumps per revolution) I've seen this on other brands which use thin stainless steel drums. (I didn't look up your model to see if the drum was SS or powder coated metal, or galvanized, or whatever) It is not a real common thing, but certainly not unheard of. I'd say it was indeed a poor weld, but the manufacturer's generally won't help much once it makes it past the warranty period. Don't bother rating this, as anything but a FixYa lowers my rating. Thanks.
Dec 09, 2008 | Dryers
Kyocera 1810 drum replacement
First, what kind of technical background do you have? Also when replacing the drum you should replace the drum blade. Most of the drum/blade kits do not come with padding powder anymore so you will need the padding powder also -- if you do not use the padding powder you will get drum blade jitter and trash the brand new drum!!!!
TO replace the drum you will need to remove the toner cart., 1-2 covers, the dev. unit (developer) and then the drum unit. You will then have to take the drum unit apart to remove the old drum and blade. *****NOTE***** DO NOT TOUCH THE DRUM SURFACE OR THE MYLAR (RUBBER PART) OF THE BLADE WITH YOUR SKIN!!!!!! The oil from your skin will damage the drum and could damage the blade, again -- then they would be trashed.
I would spend the money to have a trainer tech. come out and replace/ rebuild your photo conductive unit for you. It would be money well spent.
Oct 29, 2008 | Kyocera KM-1510 Copier
Remove photoreceptor xerox 1505
1-6-4 Image formation section (1) Detaching and refitting the image formation unit Follow the procedure below to replace or check the image formation unit. Prucedure 1. Pull the drawer out and open the front cover, bypass tray and paper conveying unit. 2. Remove the waste toner tank and toner container. 3. Remove the two screws holding the waste toner tank cover and then the cover. 4. Remove the screw holding the developing retainer and then the retainer.
5. Remove the two screws and datach the connector and remove the image formation unit.
(3) Detaching and refitting the drum Follow the procedure below to replace the drum. Cautions: • Avoid direct sunlight or strong light when detaching and fitting the drum. • When removing the drum, spread paper underneath as there is a possibility of toner spill. Toner spill can be reduced by inserting an approximately 20-mm thick pad under the image formation unit toward the developing section and removing the drum with the unit slightly tilted. • Hold the drum at the ends and never touch the drum surface. • After removing the drum, keep it in the drum case or storage bag to protect the surface from light. Prucedure 1. Remove the image formation unit (see page 1-6-27). 2. Remove the main charger unit (see page 1-6- 28). 3. Remove the four screw and blade spring, and then open the cleaning unit. • Slide the cleaning blade back and forth and insert an approximately 4 to 4.5-mm thick spacer between the retainer at the rear of the cleaning unit and the housing.
4. Remove the screw holding the drum grounding plate and then the plate. 5. Remove the E ring from the drum shaft.
6. Remove the screw holding the upper developing seal and then the seal. Figure 7. Pull the drum shaft out and remove the drum. • Detach the drum horizontally. 8. Replace the drum and refit all the removed parts. • When replacing the drum, insert a sheet of paper between the drum and developing roller to prevent damage to the drum. • Check the letter indicating the drum type printed on the new drum flange. • Securely insert the drum shaft as far as it will go. When turning the drum shaft, turn it in the direction indicated by the arrow marked on the image formation unit frame. • Rotate the drum in its rotational direction and check that the cleaning blade does not flip up. 9. After replacing the drum, run maintenance items below. • U109 “Setting the drum type “ (set to the drum type printed on the new drum flange) • U110 “Checking/clearing the drum count”(clear the drum count) • U111 “Checking/clearing the drum drive time” (clear the value)
Oct 27, 2008 | Kyocera KM-1505 Copier
MTV Games Rock Band for PlayStation 2 Logo
93 people viewed this question
Top MTV Games Video Game Consoles & Games Experts
James Wishart
Are you a MTV Games Video Game Console and Game Expert? Answer questions, earn points and help others
