Question about DeLonghi Heating & Cooling
I have a new PAC W130E that doesn't blow any cool air. the a\c compressor does cut in.
    Master:
  • 848 Answers
Just check whether the unit is getting proper power supply ...
also check whther fan is working properly
Posted on Jul 22, 2008
I bought a DeLonghi PACC120E portable a/c with no manual. The unit does not cool, and it dumps water. How do I get it to blow cool air?
I would drain the water out of the machine via the plug on the back once the unit is drained turn on, wait a few minutes. If compressor does not come on or comes on and does not cool, you need service beyond diy.
Jun 18, 2014 | DeLonghi PAC C120 Portable Air Conditioner
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
BLOWING HOT AIR
If the compressor is running but not cooling then I would start by cleaning the filter and coils as good as possible.If you can safely cut power and wash the coils then that's what I would do. If not you can blow it out with air and use a fin comb to straighten any bent fins to maximize air flow. Check refrigerant pressure and add if needed.If the compressor is not running you can replace the start capacitor and if that doesn't fix it then I would strongly consider replacing the unit. I have very seldom found it cost effective to replace compressors because by the time you are done you often have the price of a new one in repair costs.Hope this is of help to you. Good luck and thank you.
Jul 28, 2011 | Sharp AF-S80FX Air Conditioner
Put new AC compressor on, ice cold air for 2 days then blowing cool to warm air. Compressor is working but air not cold. Sometimes will get a small burst of cooler air but doesn't last.
You did'nt mention if you got the system refilled with Refrigerant after the Compressor was replaced or not. If not, that could be the problem.
Jul 25, 2011 | 1995 Mercury Villager
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
Brand new delonghi PAC C120e, I got everything installed easily with the unit rite next to the window, I have it turned all the way down and it still does not cool my small room at night. It seems to blow...
Since the unit is new and under warranty and hopefully you have registered it with Delonghi. Your best bet, is to contact their Customer Support Rep 800-322-3848. Doing it this way has you totally covered.
Jul 12, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
Pac 35 split air conditioner not cooling
Could be:
- low on refrigeraant
- loose/burned/corroded compressor electrical connections
- bad compressor run capacitor
- tripped/bad breaker in main service panel
- faulty controller components/relays
- other...
If you don't have significant experince with similar appliances/systems a service call is in order.
May 08, 2009 | DeLonghi Heating & Cooling
Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Dec 31, 2007 | Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
