Question about Gaggia Baby Espresso Machine
Gaggia syncrony compact coffee machine
Water leaking from uderneath machine, how can it be fixed?
  • jdr1962 Nov 03, 2008
    A tailored version of my complaints to Gaggia for this horribly temperemental and un-reccommendable machine -
    This photo shows some sort of repair on a melted wire which seems to  have melted again.
    Water also leaks from the bottom.
    There was nothing wrong with the seal. I have replaced it anyway.
    We don't feel it is reasonable to have a machine that is 14 months old, that has been back to Gaggia twice, the second time costing £70 for a de-scale, go wrong yet again - it seems on two accounts.
    It is now back for a third time.
    Between two de-scales we made perhaps 5 or 10 cups of coffee at the most. We were away for 2 months in the summer. How can that be? It does not seem reasonable.
    I would like to know what the insulating tape is doing inside this machine and why it has melted, a potentially dangerous situation. Also when was this done? If this was the last "de-scale" then why did we pay £70? But as we hardly used this machine between May and September, I would think this was done the first time it came in to you - still well within warrantee in May 08.
    Was this the cause of the second break-down also?
    I should also mention that this machine has tripped out (fused RCD / RCCB) the whole house / floor circuit 4 times since it came back  from the second de-scale. We probably didn't use it enough after the first descale to find out the problem.
    Sergeant:
  • Gaggia Expert
  • 223 Answers
It is very hard to say where the leak is coming from. If you can open the case of the machine a physically notice where the water is leaking from then we can tell you if you can repair it yourself or if you will have to find a service center.
Authorized Gaggia Repair Center
Cerini Coffee Services
New York, USA
www.cerinicoffee.com
Posted on Sep 12, 2008
Gaggio syncrony, water leaking from bottom after coffee is made
Remove the brew unit and clean the small hole under the white plastic valve make sure the little drain from it leads into the drain tray is clear.
Jun 25, 2011 | Gaggia Syncrony Compact Coffee...
My Gaggia Synchrony is leaking - If I remove the water catch basis, I can see a drip. We have used this machine every day for years - can the problem be fixed easily?
HI
There is a panel behind the brew unit, that has 2 screws. Remove it and clean the coffee residue behind it. That is what drains the pressure relieved after brewing, and has coffee residue that can build up and cause the leak. It should leak into the drip tray though, except when you rremove it.
Oct 23, 2010 | Gaggia Syncrony Compact Coffee...
Syncrony digital gaggia coffee maker leakage+ventilate message
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Feb 02, 2010 | Gaggia Syncrony Compact Coffee...
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia syncrony compact is leaking. Removed top and it appears it is leaking from the area that the line goes into the steam knob. Doesn't leak when using the steam knob, just when brew coffee
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Jun 14, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia syncrony compact leaking water where container joins coffee machine jim
If you remove the tank, does it leak? If yes then check the spring loaded valve under the tank, also check the O-ring for damage.
Jun 06, 2009 | Gaggia Espresso Dose Espresso Machine
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Syncrony Compact leaking
Usually these cannot be adequately fixed. To get a replacement, depending on where you are, here is the link; http://www.gaggia.com/gaggia_nelmondo.asp If in USA: Importika 596 Fishers Station Dr. 14564, Victor, NY Mr. Salzman Ph. 585.742.5178 Fax 585.924.1499 web site: www.importika.com e-mail: sales@importika.com Hope this helps :)
Aug 22, 2007 | Gaggia Syncrony Compact Coffee...
Gaggia Baby Espresso Machine Logo
445 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
