I have a Sandisk 1GB Micro SD Card with SD Adapter and it was my friends she had some stuff on it but i deleted everything when i put the card on my blackberry curve it says something about a disk error and to check for it on my computer. how can i do that? HELP !
check if the lock and unlock switche is the one cozing the problem,it might be stuck some where/on somthing, inside the sd, cz mabe u pushed to hard when pluging it, or the sd is not compatable....
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
You may have to get a card reader that takes stuff off and puts stuff on the sd card that connects to the computer using a usb port because most computers do not have an area where you can insert the micro sd card.
heya have a 4gb micro sd for my mobile phone i can put music and stuff on it but the phone wont read the card my friends say i have to activate it first how do i do this thanks>>>
you need to install memory card in phone then attach a data cable specfically for your phone (available at cell phone dealer) into phone and the other end to the usb of the pc if our phone came with software load it on pc then use the software to transfer the music files from your pc to your phone.
