Question about RCA TruFlat 27F520T 27" TV
Rainbow screen then powers off
I have an odd problem, the TV powers on for about 5 seconds, and all I see is a rainbow screen, no picture at all, it gets brighter, then darker, then shuts off, there is sound, and if you hold down the channel button the TV stays on, even if you're on a channel with picture, you see nothing but a colorful screen, and then it shuts right off. Any ideas at all? I know it's not a degausing problem because the TV wouldn't shut off if it was, I already checked that anyways. Please help me out!
  • S3V3R3D May 11, 2010
    I'm having the same problem with a Mitsubishi TS-5545. Were you ever able to resolve this?
    Genius:
  • RCA Master
  • 1,689 Answers
The degausser cricuit may be the fault. The degausser coil may be staying on, and thus forces a shut-down. It is also possible to have a power supply fault that can cause a similair effect.
The set will need shop service.
Jerry G.
Posted on Jul 30, 2008
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
Rainbow screen aiwa tv,, screen shows different colors like rainbow// brushing a magnet infront of the screen fixes the issue temporary
Picture tube is magnetized. Manual degausing is required. already you have done this.
Since you say it is reappearing, you have to check the following.
1. Relocate the TV or relocate if you have placed any tower speakers
or home theater speakers close-by.
2. Check whether auto degauss functioning OK. In the MENU
check whether you switched off auto degauss option. If it is OFF
enable it to ON.
3. Finally re orient the direction of your TV and watch the rainbow
effect. Switch OFF TV, wait for 20 mts, and again switch ON.
Repeat the process. It should disappear.
Magnetic toys or any other devises using magnet will cause this problem.
Aug 11, 2010 | Aiwa TV-S2011 20"
My son was bouncing a small ball against the screen and then it went to looking like a rainbow. Would this be the picture tube?
He may have caused some type of damage to the picture tube, but usually rainbow effects happen when magnets are present. Perhaps the ball became charged with a large amount of static, which then discharged across the tube, damaging the controlling circuits.
Jun 03, 2010 | Toshiba 36A43 36" TV
Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
Aug 04, 2009 | Panasonic Televison & Video
Philips HD/TV rainbows the picture at the bottom of set.
Hi, the convergence circuit is getting ready to fail, fix it NOW and you may get away with just resoldering the STK`s, soon they will overheat and short then it`s going to be 250-300 to fix it depending on your area rates, gl, video-tek
May 29, 2009 | Philips 60P8341 60" Rear Projection...
Dropped my TV :( Now all I see is a RAINBOW of colors...
sorry your tv is distroyed
you need a new screen
this happen to me
wave of colors that won't go away
May 27, 2009 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
42" LG RZ42PX11 Plasma - rainbow lines on whole screen but sound
hi there.its likely that the lower y-drive panel has died.this is a very common problem with this model.the easy way is to remove the panel from the set completely,power it up and you should be greeted with the top half of the picture.this means ic failure,usually the bottom one for some odd reason.not replaceable unless you have the gear,these ics are available from dalbani(nikkai)for those interested.be extra careful with the four ribbon cables when removing/refitting.damage to these writes off the display panel.hope this helps somewhat,regards,steve.
Feb 03, 2008 | Televison & Video
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
25TS56C22125
The description of the problem points to the picture tube being bad because of the rainbow colors,as far as the white lines you might have an open resistor in the crt board,a qualified technician should take care of the problem if the set is repairable and He will know as soon as he sees it.Good luck.
Sep 17, 2006 | Philips Magnavox 27MS343S 27" TV
RCA TruFlat  27F520T 27" TV Logo
125 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
