Question about Audiovox Televison & Video
When DVD is put into portable DVD player and top is shut DVD is not spinning inside. Error message states "no DVD"
  • tiacapo Jul 22, 2008
    This has happened on 2 audiovox DVD players. The cost to repair is not worth it. I bought them for under $100.
I also pay 15 for broken units with any accessories you may have.
Posted on Jul 22, 2008
Portable DVD player won't recognize door is closed.
My guess would be that the switch inside that the tray hits to tell the dvd player it's closed is broken.
Aug 23, 2012 | Philips portable dvd player phillips...
My Funai WV805 DVD player quit playing DVDs
Hello
If the DVD do not spins inside the playere, this type of fault can occur. Open the top cover of the player and insert a dvd. See whether it spins inside or not. If not, replace the motor that spins the disc inside. This motor is known as Sled motor.
If disc spins inide and the player do not read or play it, replace the Laser Pickup Unit. It is faulty.
Mar 01, 2012 | Televison & Video
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
My fukuda dvd player won't play any dvd or cd.It always show the "no disk " error even if there is already a cd/dvd inside.Already remove the top cover and saw that the disc is spinning but will...
Either the spindle motor is not reaching the required speed to read the table of contents, the traverse motor is in the wrong place and won't allow the disc to be read or the laser is faulty.
It could be any combination of the above. Time for a new player?
Feb 04, 2011 | Televison & Video
Everytime i put in a DVD it says "Loading" on the
There is problem with Optical block need to replaced.This Model is new and still come in under Warranty.SO check your Warranty card and calim your near Sony service centre.
Nov 15, 2010 | Sony DVP-FX930 Portable DVD Player
Put in an original DVD and i get an error message no disk
you probly need a good clean of the laser or
replaced....
have a nice day
May 06, 2010 | Coby TF-DVD7005 Portable DVD Player
H02
The HO2 message means the disc is not spinning,it's not about the lens
or the laser.It is easy to take the lid off.Once you do that,plug it in,open the tray with the remote,put in a DVD,close the tray and then give the white plastic wheel on the top a gentle little nudge to get the disc spinning.
Jan 30, 2010 | Panasonic DVD-LS50 Portable DVD Player
Mintek portable dvd player
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 08, 2009 | Mintek MDP-1815 Portable DVD Player
Coby Model Number TF-DVD7005
Paul Sim, coby portable dvd player model TF DVD7005 keeps coming up with an error message that says NO DISC regardless of whatever disc you put in, the player comes up with the message LOADING on the screen and then stops after a little will and comes up with the NO DISC message
Dec 10, 2007 | Coby TF-DVD7005 Portable DVD Player
Televison & Video Logo
67 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
