Paper jam Had a paper jam AND removed paper. Checked multiple times front and back to be sure there was no paper left. Also did shut down and restart. Still get a "carriage jam. Clear carriage jam" message
  • quantask Jul 22, 2008
    It is a Konica Minolta QMS 6100 2
    Hope you can help
    Is about 1999 model so has been superseeded now
  • 163 Answers
What make and model do you have? I have experienced (and fixed) similar trouble with Lexmark.
Posted on Jul 22, 2008
  • John Byse
    John Byse Jul 22, 2008
    What I have found on the Lexmark is there is a small Mylar timing strip that the carriage uses for tracking its location.
    This strip is usually behind the carriage, running left to right. Sometimes the strip pops out of the groove on the printhead, other times it can become disconnected when removing a jam. It is secured on one side with a loop and should have a spring for tension on the other.
    It is very small and hard to see.If you find it, center the carriage and try gently lifting up and allowing the strip to rest naturally in the sensor (groove).
Paper jam door - I cannot open this no my HP 8250.
Turn off the printer, then unplug it from the power source. Clear the
printer of any paper that may be obstructing the paper path. Remove the rearaccess door. Gently remove the jammed paper from the printer, then replace therear access door.
Remove the rear access door to clear paper jams.If you cannot remove all jammed paper from the rear area of the printer, tryremoving paper jammed in the middle of the printer by opening the paper jamdoor located inside the top cover.
Open the paper jam door to clear paper jams in the middle of the printer.Plug the printer back in and turn it on.
In case of any doubt go to the following link and act accordingly
Sep 25, 2011 | HP Photosmart 8250 InkJet Printer
Paper jammed when loading paper, don't know how to clear jam
Welcome to FixYa.
To clear the paper Jam, follow the steps below.
1. Remove all loose paper from the paper In tray.
2. Do not pull paper jam from under the front cover.
3. If there is more than one sheet stuck in the printer, remove the paper sheet at a time.
4. Make sure no scraps of paper are stuck in the printer.
5. If there is open the door at the back of the printer.
6. Pull the jammed paper out of the printer.
7. Check again to make sure no scraps of paper are stuck in the printer.
8. Close the back door.
9. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Mar 24, 2011 | HP Photosmart 2610xi All-In-One InkJet...
I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Jan 11, 2010 | Canon imageRUNNER 2200
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Lots of potentials here.
The corona wire may have become dirty in the jam. That will cause it. Both the front and back door have to be shut. See to it that their respective switches are activated when they are shut. Read your owners manual. It is full of suggestions for this issue.
Oct 07, 2009 | Brother HL-2040 Laser Printer
Paper jam
Some of the Ink Jets have a cover in the back of the printer that you have to turn a lock to remove and you could have some paper stuck back there.
Mar 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
Error Message - Paper Jam
I had a paper jam. I removed the offending sheet of paper which unfortunately tore into 4 pieces as it came out. Upon piecing the sheet of paper back together - there is a small piece missing. I've checked the printer thoroughly - nothing can be found!
Feb 25, 2009 | HP Officejet Pro L7680 All-In-One Printer
Will not print / cartridges will not move back and forth
I had this happen to me the other night and I had to restart the printer to get the print job out of the que. You could try that.
While it's restarting, unplug the power cord and the usb cable. That should reset it.
Jun 21, 2008 | HP DeskJet 5550 InkJet Printer
My brother laser printer HL-5050's paper light is flashing, which usually indicates a paper jam. i've checked 5 times and there is no paper jam. have shut off printer and restarted 3x. when i try to print,...
I've nearly the same problem....My printer(HL5050)  takes only a little bit of the sheet, then paper led flashes.
I've found a block into the paper feeder. This printer is impossible to disassemble.!!...even if I've the service manual, because for taking away a simple pressed paper block , it's necessary disassembling  almost all the machine!!! No comment
So I'd an idea:
I've sprayed into the paper feeder a great quantity of a cleaning spray (without oil) , in order to get the paper block wet, then , by means a school-book plastic cover, used like a paper sheet,  and  manually acting on the gear, I've pulled this plastic sheet up and down several time (spraying in the same time)in order to  remove these hard paper blocks. Now my feeder seems free. Tomorrow I'll try to test it.....
PS To do this it's necessary the only removal of left cover, in order to reach the gear which allows the paper to advance manually.
Apr 21, 2008 | Office Equipment & Supplies
137 people viewed this question
