Question about Pioneer DEH-P6900UB CD Player
WEARD DECK PROBLEM
I HAVE A 1970 CHEVY C10 THAT I PUT A DEH-P6900CD PLAYER IN AND IT KEEPS SHORTING OUT OR GROUNDING OUT THREW TH RCA CABLES SOME HOW ITS SOMETHING LIKE THAT THIS IS THE SECOND DECK I HAVE HAD TO PUT IN THERES NOTHING WRONG ELECTRICALLY WITH THE TRUCK THE DECK WORKS FINE FOR THE FIRST 6 MONTHS THE SOMEHOW IT SHORTSOUT OR GROUNDS OUT THREW THE RCA CABLES IN THE DECK AND EVERY STERO SHOP TELLS ME ITS THE DECK BUT I DONT THINK SO NOT TO TWO DECKS I THINK SOMETHING ELSE IS WRONG PLEASE HELP
Replace your RCA cables. You may have a short ie screwed into it during wrap-up.
Posted on Feb 01, 2009
Radiator wiring
you will have to run a fan switch into the cooling system pipe that u will wire up thru a 4pin relay so as the water temp reaches 90 deg it will switch fans on
Aug 11, 2014 | 1963-1970 Chevy C10 - StrongArms Front...
Will a amp work with this deck
you can get a amp to work on any deck although u may have to rig it a little bit all u need is sound coming from the stereo and if u will take the rca one end and cut it and strip it u have a wire inside each one and then u have ground wires surrounding the inside wire twirl them up like 1 wire and then strip back the inside wire hook that one to front left pos wire and hook ground wire to front laft neg and do the other rca wire the same just hook it uo to front right or if it has rca jacks on the back of the stereo just hook ur rca wires into them and to the amp
Feb 24, 2010 | Pioneer DEH-1600 CD Player
How to hook Iphone up to Pioneer DEH-P8200r
Without an input on the front, the only way to hook it up would be to put an FM modulator either hard wired in line with the antenna, or over the air. There are more expensive options, but this will work just as well. I would go hard wired because over air is more trouble than it is worth. Don't use an XM radio hardwire kit, it only works with XM.
Oct 16, 2009 | Pioneer DEH-P8200r CD Player
IPOD ADAPTOR
you have to buy the ipod connection kit to pioneer, but if your deck have RCA input at the back..all you need is Y cable 2 (RCA male - 35mm jack)
RCA will be connected to DECK, 35 mm jack to your ipod.
to use your ipod...change the input setting on your deck to AUX (auxillary) most deck have this for CD Changer connection
Good Luck
Mar 13, 2009 | Pioneer DEH-P6700MP CD Player
Pioneer deh-2800
I can't figure out how to set the clock it isn't even in the manual
Oct 18, 2008 | Pioneer DEH-P2900MP CD Receiver...
No rear output
yea your ic in the deck is going so i suggest you buy one which is cheaper than buying a new deck
Sep 15, 2008 | Pioneer DEH-P5800MP CD Player
RCA jacks not working DEH-P470MP
does the amp turn on when the deck is turned on ? is the ground hooked to the body of the car to bare metal w/out paint ect ...under it ? you may want to take it to a installer there are many things it could be they can also test your rca outputs if thats the problem. curcuit city is a cheap place to have your equipment tested if you live close to one
Aug 07, 2008 | Pioneer CD Receiver - DEH-P470MP - CD/MP3...
Bad preoutputs?-thumping noise from sub preout?
There is a small surface mounted fuse inside the radio for the pre-out grounds. that fuse must be replaced. Only somebody who knows these radios and has good soldering skills can fix this.
Apr 13, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer DEH 3700 ground problems/system noise
Very common with pioneers. their is a ground loop fuse-located inside the head unit, that has to be repaired at the factory. Or, the best way-just like you said, is to ground the rca's, solder a thin wire to each rca, easiest and cheapest way. I had it happen to me with a 4800.
Mar 23, 2008 | Pioneer DEH-3700MP CD Player
Ipod Connection through RCA Cable
Actually, what I think gbaity is doing is utilizing his IP(Interactive Pioneer)-Bus port in the back of the DEH-P3000, which is an input port designed to allow the deck to use an external multi-disk CD changer. All you need is the CD changer, then change the input source from your deck to "M-CD". There are folks on eBay and other places that sell a cable that pluggs into that very same port. They are designed to allow the unit to accept input through the IP-Bus from an ipod or just about any low-level input that you can pass through the RCA jacks. I have the same deck, and also just purchased an ipod cable for the IP-Bus, and it also does not work. I have been told that I need to switch the "M-CD" input source to "AUX" as the input, but I do not know how to do that. pressing the input source button only displays "CD", "M-CD", and "FM/AM". Does anyone know how to add "AUX" to the choices or otherwise show us how to make these cables work? Thanks - TomR
Aug 23, 2007 | Pioneer DEH-P3000 CD Player
Pioneer DEH-P6900UB CD Player Logo
67 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
