Question about RCA P52960 52" Rear Projection Television
Front buttons and remote don't work
I inherited a RCA P52960 recently. The picture and audio seem to work well enough, at least at displaying snow, static, and the menus. However the buttons are very confused, the power button does nothing and the volume up button turns the TV on. Only one other button works and it seems to jump through menus at random. In addition I have a Comcast universal remote and none of the codes it lists for RCA seem to work at all, I can't even figure out where the IR receiver is. I don't have the G-Link cable, if that means anything.
  • Anonymous Oct 31, 2008
    I have the same problem with mine it and it has po vo 1.22 on the display once i was fooling around with this po vo thing and got it to work again remote and everything back to normal for about two weeks then it went back to the messed up buttuns
    good luck to you
  • Anonymous Jan 02, 2009
    Same thing....it is my dad's TV and his tv says po vo 1.22....the TV button is the only thing that makes the TV do anything...it takes us to a menu and then there is no way to control anything! It just jumps around. My opinion is that the electronics are too old from the generated heat and it needs new guts! Anyone have a clue? thanks
BMW Rider
  • 232 Answers
SOURCE: Cannot operate tv manually or with remote
may have a corrupted eeprom which means you`ll have to call a tech, one thing you can try is;
Un-plug the tv`s AC power cord, wait 30 seconds, plug back in and pray, this will set re-set the micro to the default mode which may have gotten glitched by a power surge, hope it works for you.
Posted on Nov 30, 2007
  • 12 Answers
SOURCE: Programming the remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Posted on Dec 15, 2007
SOURCE: RCA 50" DLP, model #
Did anyone ever answer this question? I am having the exact same issue.
Posted on Oct 28, 2008
SOURCE: Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Posted on Nov 09, 2008
SOURCE: I need a Universal Remote code for this model.
I got it to work with code 12002. I have the Comcast DVR Remote.
Posted on Dec 01, 2008
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
Dec 22, 2012 | RCA P52960 52" Rear Projection Television
RCA P52960 goes black
does the audio still work? If so I would suspect the vertical out IC
Aug 07, 2012 | RCA P52960 52" Rear Projection Television
My RCA tv won't work without a remote, and I can't seem to reset since I don't have a menu button
Hello
If your TV has no menu button on its front panel, there is no other way than buying a universal or original remote control to this set.
Mar 04, 2012 | RCA Televison & Video
How do i adjust tv for better picture
use your remote, push menu button and click on the video, farely easy, some tv's also have screws in the back of tv to adjust picture, hope this helps
Dec 30, 2010 | RCA P52960 52" Rear Projection Television
My rca p52960 tv will not turn on at all. What can
I would disconect the front control panel you can do it by opening the back of the unit on top of the light box there is a couple plugs just unplug the one going to the front panel then try to turn it on with the remote
Jan 25, 2010 | RCA P52960 52" Rear Projection Television
Channels keep changing without buttons or remote buttons being pressed
Front panel contact switches clean all of them with contact cleaner or replace them common problem. Mats has them 29cents 1-800-628-1118
Dec 15, 2009 | RCA P52960 52" Rear Projection Television
The picture is bigger than the screen... Picture is cut off and when I unscrewed the back of the tv I could see that the picture was showing perfect but it was to big for the screen... There's not a way to...
Have you tried hitting the format picture button on your remote control. Seems the picture is in zoom mode. If you have a cable box for HD Channels then look on the remote for a button (format) or Screen size.
Nov 11, 2009 | RCA P52960 52" Rear Projection Television
Rca model p61960 projection tv dead
More likely a bad flyback transformer......T.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
RCA P52960
try a combonation of buttons on front of tv-- hold vol up & chan up fo four seconds?? try menu & vol up for four seconds,etc. Consult o/manual?
Sep 05, 2007 | RCA P52960 52" Rear Projection Television
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
RCA P52960 52" Rear Projection Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
