Question about Dryers
Kenmore Electric Dryer. 110.76494 Dryer will not continue to run after the start button is released. Will run and heat up if the button is continually held down.
  • 550 Answers
The start button sends a electric current that starts the motor and latches a relay/solenoid. the relay is damaged and does not latch, it needs to be replaced, is not expensive, and simple to find with the model number given above, at your local parts store. buy the new one first, the store guy will tell you which panel to remove to locate the old one, I am unsure, just remove one wire at a time and place it in the same terminal on the new one.
Dryer will - fce7208.jpg the pic is a 'typical' wiring diagram (actually maytag) the start switch and relay are represented in the center.
Posted on Jul 22, 2008
Button starts dryer, but stops as soon as button is released
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Apr 09, 2010 | Kenmore Elite HE4 Electric Dryer
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
My dryer will not continue running after I release the Start button. Is there a latching relay inside? Does it have an electronic control instead? Could it be a bad moisture sensor? Sears Kenmore...
There is a relay in the control panel. It also has an electronic controller.
There would not be a latching relay, usually the start button energizes a relay, and they use a NO contact wired parallel to the start button.
There should be a schematic in the dryer some place. You'll have to use your voltmeter and test the unit to find out which component is failing.
Nov 12, 2009 | Kenmore Dryers
Dryer start button
The motor switch is not switching over. Either the switch is bad or the dryer is not tumbling fast enough to activate it. Eric
Aug 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryers Logo
153 people viewed this question
Top Dryers Experts
