LG 52SX4D-UB color problem
No reds in the picture - everything else seems to work fine. I redset the factory defaults for the video, but the problem persists.
  • Anonymous Nov 11, 2008
    LG 52SX4D-UB
    Did you ever hear anything on this one. My parents set is doing the same thing. All fine one night, powered on to no red the next day. Greens and Blues and grayscale
After numerous hours of searching the internet and purchasing a new color wheel I found the real problem. If you replace a color wheel or even the lamp you need to be able to get into the Service Menu. This is something that the repair technicians don't want you to know. With the tv that I have the original owner was told by a repair tech that it would cost about $800.00 to repair. After the tech left the problem was worse than before he got there. After getting into the Service Menu I found that the Contrast was cranked up to 115% and the color wheel setting were way ! way !! out of adjustment. This sounds to me like a repair person trying to make some fast money. I am posting this proceedure so that others will not have to go through what I and the original owner have gone through. Also here is a link to the site that I found this information. They are a good reasonable site for a soure of parts. http://www.replacementlightbulbs.com/lamplg52sx4dub.html
Instructions for resetting counter:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Posted on Jan 22, 2010
My LG projection tv (serial number 52sx4d-ub) won't turn on, an orange light flashes then turns red. How do I know if I need to change the bulb or the ballast? And how much does it cost to change the...
Orange blinking light under a small picture of a light bulb? Then turns to a red light?
Sounds like the same problem I had when I picked up my LG 52SZ8R. After replacing the lamp the TV ran fine.
Easiest way to see if the lamp is the problem is to take it out, and look at the peice of wire in the globe as you would an old light globe.
If you need help, download the following manual, and look at page 9.
http://www.jordansmanuals.com/ServiceManuals/LG/TV/PROJECTION/62SX4R/62SX4R%20Service%20Manual.pdf
If it does come down to you needing to replace the ballast contact: http://www.statewideapp.com.au/index.php?selectedContent=1188381775
They should be able to give you a quote and part number, if you don't like their quote you can always use the part number to search for one thats cheaper.
Mar 07, 2011 | LG 52SX4D 52" HDTV
I can hear the sound but i can only see the picture in Video mode and PIP mode..... LG model # 52sx4d-ub
dcooper1288,
You have a bad mainboard.
They are available at http://www.encompass.com and are not that difficult to replace. This is a common problem with the LG units and don't be surprised if it takes a while to get a board.
Thanks for using FixYa and for the generous rating.
hardrocko
Sep 27, 2010 | LG 52SX4D 52" HDTV
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
How to reset after replacing bulb
mute on remote+ok on tv panel at the same time
Jan 24, 2009 | LG RU-52SZ30 52" Rear Projection...
Lg RU-52sz30 rear projection tv does not go on
I have an lg dlp projection tv Model # 52sx4d-ub.I replaced the bulb,everything correctly,but no picture. LG says I have to have a tech come out to reset? Can you help.
Jan 23, 2009 | LG RU-52SZ30 52" Rear Projection...
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
No picture
set is gone it shut down,call local service dept.
Apr 12, 2007 | LG 52SX4D 52" HDTV
Televison & Video Logo
522 people viewed this question
Top Televison & Video Experts
Electro Med Services...
