Back to:
Fuji FinePix A360 Digital Camera
Negative
posted by willsmirnoff on Jul 22, 2008
everything displayed is in negative color. Is there a setting to reverse this or is my camera broken?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2008
Not Rated (0)
pishta68
Rank:Wiz Wiz
Rating: 83%, 205 votes
You are in a special effects setting, called negative. You can change this, try the F button or go into menu and choose default or A for automatic. REmove batteries for 3 days if all else fails.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on negative:
I don't want to Accept this solution
Can you Help with these Digital Cameras problems?
when camera is pluged in the communication error comes own...
green light flashes and then nothing any ideas
my camera wont turn on it flashes green and wont go on the...
A360 Powers on and immediately shuts down Hit the power...
When i take a picture it will have small lines going thru...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
