The color on my tv is messed up. You can still see the picture its just you can see all the colors that make up the picture.
  • taizy0303 Aug 05, 2008
    I have the same problem, tv looks 3d, with the green color of the convergence off! please help. model av-56wp74 yr. 2003 jvc
  • skelley07 Nov 18, 2008
    green is distorted. top and bottom or pinched towards center
  • 8,617 Answers
Does the pictyer appear as 3D? Are you able to adjust the convergence on it? Please respond to this same post when replying and please list the model number of your set and I will try to assist you with the problem.
Posted on Jul 22, 2008
Dp32746 Sanyo Picture is messed up?
try to play a DVD on your TV to determine if the problem is on TV or signal..
If the DVD plays same image you have bad t-con board,.,just replace it to fix the problem..
Aug 25, 2012 | Sanyo DP32746 32 in. LCD Television
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
Tv works good picture is good and clear sound is good but im only getting blue and red colors??? is that the board? or the green bulb?
That is what happened with are tv. My husband took the tv apart and started messing with everything and got the tv to line up better. he just turned the nobs and messed with the coloring.
Dec 09, 2009 | Hitachi 61HDX98B 61" Rear Projection...
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Color wheel
could be a jumper on the DMD board that must be removed, look for a small sticker that points to the jumper, or it could be a setting in the factory mode, mute-182-power will get you in there, check the settings for the color wheel
Jul 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
TV is messed up
Hello ehh1,
Can you provide a photo of the screen. It would help with the diagnosis.
Thank you
Dec 27, 2007 | Sony KP-51HW40 51" Rear Projection...
TV coloring messed up
my sony did that but would turn off and not leave on. its not recommended to use like that (from tv repair man). theres a chip inside the tv that blew. it cost me 260 bucks to get someone to come and fix it.
Nov 01, 2007 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
