Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Convergence problem colors are out of focus / TV showing Double
My television is only 4 yrs old, the problem I have is the other night I had a power surge, and the power was momentarly knock out, when power was supplied to the television nothing seemed wrong. When we awoke the next day, the television was out of focus, I tried the automatic convergence it went through it's process and nothing happened. I then tried to manually adjust the color and nothing moved I decided to called the television repairman the next day, He replaced both convergence modules, and when I turned the TV back on the same problem existed. how can i fixs this problem?
  • 32 Answers
He may have replaced the IC's but in this business you always run across a bad order. use this link http://www.tvrepairkits.com/xcart/home.php?cat=2954 to order everything you need. They do a very good job at putting together a package for the consumer to be able to fix there television. You will recieve convergence IC's, resistors, thermal paste, and step by step photo instrucions.
Posted on Mar 01, 2010
Colors on tv are seperating. looks like double images.
Hi, Try the auto convergence or auto focus to eliminate the problem, if this does not work, you may have to get the TV repaired, the common problem are the power amplifiers that correct the color convergence, that is why you get color shades or ghosts in the images.
Nov 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
My smasung hdtv 1080i is about 8-10 yrs old. it
you have a convergence problum. The convergence ics go bad about every 6 years
Apr 15, 2010 | Sony KP-53S65 53" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
57HX81 projection tv,color is mostly red and picture is double.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
I know that I need a convergence power supply board.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 27, 2009 | RCA R52WM24 52" HDTV Projection Television
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
  • Screen looks 3D
Mar 16, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
Color convergence?
Can anyone give me the resistor values for location RK 42, RK 46 and RK 62? Hitachi 46F500 TV. Or can I be pointed to the location of a service manual?
Tony
Sep 13, 2007 | Hitachi 46F500 46" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
