Question about Radio Communications
C b radio
Why do i have so much background noise my swrs are at 1.1
and i cant recieve like i should or get out like i should
lets see what u guys know
Make sure your antenna is grounded well,also check for neon lighting near your transciever.
Posted on Jul 24, 2008
I can hear my friend but he cant hear me..... swrs on both are fine,,, both base stations, im using a homebrew dipole and hes using an upside down whip stuck to a ceiling grid
First of all, how far are you from your friend? Second, he does not hear you but does he hear anyone else on his radio? If not, he might have a receive problem with his station but it's not his antenna. If he hears other traffic, your signal does not get out. If you don't have anyone else in the area, swap antennae with your friend and this will tell you if it's antenna related or radio related. Let me know what you find out or give me more info! Good luck!
Feb 01, 2014 | Midland Radio Communications
Cant adjust swr on cobra 29 with swing kit
make sure you have no noise in the background at all the be my guest. you may have to put a cloth over the mic speaker to keep the noise level down but you can do it.
Jan 28, 2014 | Cobra 29 LTD CB Radio
Ranger superstar 33 no recieve
If you're still getting loud squelch noise but do not receive on any channel, you must check the RF from the antenna to the audio stage(not included). There must be more than just one RF stage in this radio. Let me know what you find.
May 08, 2013 | Radio Communications
Background noise problem with motorola radius cp200 and also crackling status during transmissions
If the crackling and static are coming from the radio, it could mean 1) Something in your environment is putting out RF (radio frequency waves). 2) You have an old battery. 3) You are at the edge of the radio's range. 4) You have a bad speaker in the radio.
Possible solutions for you could be:
1) Have the radios reprogrammed to have Private Line (PL). This would block out RF noise on your frequency. Also, within the factory if there are devices putting out RF noise, there may be some solutions for them.
2) Replace old batteries. (Try a known good battery and see if it helps.)
3) Check to see if you have the same problem when radios are within a closer range. If it is a range problem, education yourself and other users to hold the radio upright (perpendicular) to the ground. You will get the best range. Tilting the radio can reduce range as much as 2/3s. Even the bodyfluid of a person wearing the radio can absorb range.
4) See if you have the same problem with another radio, or if the crackling static is just with the one radio. It may need repaired.
Another solution for you might be a noise canceling remote speaker mic. This would put the speaker of the radio up on your lapel. And these mics also have some noise/wind canceling ability.
There are a few programming things you could have your local dealer try. They may be able to tighten up the squelch and knock out some of the noise.
Best regards.
Mar 11, 2013 | Radio Communications
Cant hear other radios if over 1/4 mile away
Are you using the noise blanker? Are you also finding noise on regular AM radio in vehicle? How good is the connection on the coax?
How good is the antenna ground to chassis? How good is the antenna?
If you address the various sources of general RF hash that would also aflict the AM reception in your vehicle, that would be the first thing to address. It would probably be a good idea to use some contact cleaner or LPS1 and spray down the switches and controls. I know on one of my own that the dirty contacts are enough to kill off reception.
If these things do not improve it, and you do not mind going into the radio- in the reciever stages are a number of 1N60 diodes, and they have a nasty habit of becoming leaky and noisy. Replacing them should help quite a lot if nothing up to this point has.
Jan 27, 2012 | Cobra 29 LTD CB Radio
How do i cut a cb anntena to calabrate it?
If the antenna was designed to be used on the CB band, you should NEVER have to cut it. Calibration is a matter of moving the rod up and down in the post above the coil. There is a set screw that you loosen to accomplish this. Check the SWRs after each adjustment, and adjust until the SWRs at channel 40 and channel 1 are about the same.
If it's a 1/4-wave wip, you get what you get, there are no adjustments.
If you can't adjust it properly using this method, then you have some other problem; bad/poor ground and/or ground plane, bad coax, etc.
NEVER CUT (TRIM) AN ANTENNA THAT WAS DESIGNED FOR CB USE! Period! If it can't be tuned, you either have a faulty antenna, or some other problem. You need to find the problem and fix it, not mess with trimming the antenna...
Dec 03, 2011 | Cobra 29 LTD CB Radio
Need to tune and peak my midland 1000 cb
sounds like a problem to me . I have one that was in fair shape that had the same symptoms , I pounded the crop out of it with a hammer and now it doesn't recieve anything . You can't find a service manual for it ,unless midland will sell you one but don't hold your breath . Remember a 26 oz. hammer works good but not the radio.
Apr 07, 2009 | Midland 1001Z 40-Channels Base CB Radio
Picture will not display on my samsung sgh-u600
Probably the ribbon that connects screen to keypad
common fault on this phone
Aug 12, 2008 | Samsung SGH-U600
Radio Communications Logo
59 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
