Question about HP Office Equipment & Supplies
HP 500 PLOTTER ERROR CODE 6303 - HP Office Equipment & Supplies
  • selfnetwork2 Sep 28, 2009
    when am i turn on the plotter after installation the warning 05:10 has been displayed than press enter the plotter are ready
HP 500 system error 21:10
Posted on May 18, 2009
How to fix the following trouble message please thank you beforehand
This info is for technicians and explanations for the codes is limited to them
Jun 23, 2016 | HP DESIGNJET 500 InkJet Plotter Printer
71:06 error code
hello,
Description:
Out of Memory problem. This Error Code only appears in HP DesignJets 800 Series, or in the HP DesignJet 500 Series with an
HP-GL/2 card installed, when processing either a PostScript or HPGL/2 file.
Corrective Action: Try the following:
Check the amount of RAM in the Printer using the Front Panel
(use the Printer Information utility aPage 4-27). If necessary,install more memory into the Formatter.
If the problem continues, try processing the file in the PC instead of the Printer (select Avoid out of memory in Advanced options in the Driver).
hope this helps
Mar 03, 2015 | HP DESIGNJET 500 InkJet Plotter Printer
Error 17:11 Hp 500 designjet plotter
error 17:11 no way related to DSJ 500.. Pl check
Dec 12, 2012 | HP PRINTER,DESIGNJET 500 42'' InkJet
Hp design jet 500 error code 5613?
System Error: 56:13
Problem
Description:
Error in the Drive Roller Encoder Sensor quadrature.
Switch the Printer Off and wait a few minutes. Switch the Printer
On again and check if the Error Code has disappeared.
If the Error Code continues, replace the Drive Roller Encoder
sounds like the media motor encoder is dirty or has failed , there are videos on you tube on how to get to the sensor ,OR if your not up to it I would recommend Belmonte Business equipment as being much cheaper than HP to resolve your issue
Nov 29, 2012 | HP Hewlett Packard Designjet 500 42" Wide...
My hp designjet 500 doesn't recognize the I/O Card
By I/O card I assume you are referring to your JetDirect or the optional HP/GL2 formatter board, your EIO devices?
If you have them installed and the plotter does not recognize them.
Shut down the plotter then remove the power cord from the plotter or the wall and wait 5 mins.
Remove ALL EIO devices (JetDirect / formatter).
Plug the plotter back in and restart the plotter.
Test functions of the plotter.
Shut down the plotter and then add back only the JetDirect.
Start the plotter and check the function, and check if the menu will allow you to setup the JetDirect.
If successful, shutdown again and reinstall the Formatter Card (if you use one).
Test functions and check the I/O setup in the menu.
The idea in a nutshell, remove the cards and add them back one at a time to see which one if any is bad and causing the I/O to shut off.
If this does not help, you may need to replace the plotters Electronics module
Aug 16, 2012 | HP DesignJet 500 InkJet Printer
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
447 people viewed this question
Seeker5211
Seeker5211
