Question about Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Unwanted horizontal lines
We get these continuous (white) horizontal lines at the very top, about 10% of the CRT screen height. It detracts quite a bit from the quality of the picture. This is now for about 2 years.
Is there any adjustment for this I can access, or what is a possible cause/solution.
The product is MW27FN1C and was purchased July 2003.
  • 2 more comments
  • blgardn Jul 27, 2008
    I have a 27" model MW27FN1 with the same horizontal lines at the top 4" or so. I know the only adjustment is vertical position. Can I replace the circuit board with the vertical circuits?
  • Anonymous Dec 01, 2008
    Unwanted horizontal lines problem
  • janaindc Dec 01, 2008
    Same horizontal lines on my TV. I've read the solutions, but I'm not technical and wish someone translated "caps, CADs" into plain English. Another problem is the DVD player: DVDs get stuck every now and then, DVD player won't open even though the motors keep running. Obviously, not a good TV model :(...
  • Anonymous Mar 06, 2009
    I have well had the same problem with the lines and replaced C427 that fixed thank you guys so much!!!!
I had the same problem on a 2003 Toshiba 32A13 TV. I replaced C407, 100 uF 35V and it fixed the lines. I noticed that this capacitor was mounted near the heatsink for the vertical output IC. I don't know if the heat aged the capacitor faster or not. The only cost was $9.99 for a 32A13 service manual download. I had a new capacitor in my misc parts box and it has a 105 degrees C rating.
Posted on Jun 17, 2012
  • travishill02 Mar 29, 2015
    This fixed my Toshiba 32A13 TV. Bought a capacitor for like 1$ and replaced C407, found a site to download the manual free!
    Thanks for posting this fix
    New Friend:
    Problem Solver:
  • 6 Answers
Well that depends on 1) what have tried to fix it, have you tried a reset on the monitor or any other tools that are available on it. 2) have tried updating the drivers for the monitor or your graphics card. in lew of that there could be a component thats going to fail. Personally CRT's are out dated I would get a flat pannel if its affordable for you price wise you can get a good one very reasonably priced
Posted on Mar 29, 2015
It is C427 electrolytic cap 100uf @ 50V. I had same problem - just replaced it on 2003 Toshiba TV and all is back to normal. Cost $1.5CAD for the part, $16CAD for soldering iron, $2.5CAD for solder and $8CAD for solder ******. New cap is a bit larger then original - no issue.
Posted on Nov 02, 2008
Vert. circuit shows IC 401 LA78041, pumpup Lytic C427 is 100 uf@ 35v., c421 4.7@50v, c429 100uf@35v, c430 2200uf@25v, c438 100 uf@ 6.3v, c434 1000 uf@ 35v, r429 1.5ohm @ 1/2w, r434 1.5ohm @ 1/2w. Try caps first in order above start with C427 ...
Posted on Oct 27, 2008
What is Horizontal scan output fault? is HOT is faulty or other problem?
Horizontal scan is the scanning left to right on the screen to make up the width of the picture. The height of the picture works the same. This is not an easy thing to repair. You will have to find someone wit the experience to troubleshoot it.
sorry but hope this explains a little.
Jan 28, 2015 | Televison & Video
We have a 27" MTS Stereo color TV. There are white horizontal lines at the top of the screen. We do have a DVR with Direct TV. How do we fix?
U can't.Only horizontal lines on the top parts of the tv screen or the lower parts of the picture screen.Or very light horizontal lines mix in with the tv screen pictures.The "CRT" the picture tube is slowly dying of old age.Quicker than they supose to.The late 90" these problems case show up alot more in standard tvs using CRT tube.Because the CRT and analog design about to be faze out of the market place.The glass molding and those radiation matrials,they used to make those "CRT" picture tube materials,not as good as before.
Aug 03, 2010 | Sansui Televison & Video
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Is there a vertical height adjustment on the Toshiba 27A3. Thanks, Ian
yes there is but there are 3 capacitors in the vertical circuit that go bad causing a height problem,white lines on top,or a very small height. change the capacitors in the vertical section.the yoke on the back of the picture tube has 2 coil sets on it,one is horizontal,and the other is vertical.the connector next to the flyback transformer is the horizontal. follow the wiring from the other connector and it will take you to the vertical drive ic located on a heat sink.the three capacitors go bad because of heat from the heatsink cooling the vertical drive ic.
Jul 13, 2009 | Toshiba 27A34 27" TV
Thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Jan 17, 2009 | Televison & Video
White lines & inverted picture at top of CRT TV image
This problem is normally the Vertical filter capacitors. You need to have them changed before it burns out the Vertical Chip.
Good Luck
Ed
NC Electronic
Mills Wyoming
Jan 07, 2008 | Televison & Video
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Toshiba MW27FN1 27 in. TV/VCR/DVD Combo Logo
550 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
