Question about Danby DPAC8399 Air Conditioner
Danby 3899 Fan does not start
I have a Danby DPAC3899 where fan will not start on its own, Fan capacitor checks out OK, fan will run once its push started, but will not start on its own, just "twitches" back and forth a coup0le of times. Brushes maybe?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
I'm not an AC guy, but I had a similar problem with an AC unit at home it turned out to be the motor itself. Another time it was the relay. Did you try tapping the motor when on to see it it would turn?
In my case I used to whack the motor and after a couple of times it would turn, until it just wouldn't work anymore.
I sounds to me like the motor/ brushes, since it runs after being pushed.
Posted on Jul 22, 2008
I have a S24AWN-U56 condenser fan doesn't start once pushed with a screwdriver fan runs , is there s start capacitor for the fan?
There is no start capacitor, but there is a RUN capacitor. More than likely it will be a 'combination' run capacitor that shares the common terminal of a dual capacitor with a higher mfd side for the compressor. Typically a 35/5 or 40/5 rating is what you'll see on the side of the capacitor. It will be grey in color, possibly round or oval and near the size of a soda can.
What you are describing is a motor trying to start without the aid of its run capacitor, which momentarily allows a bit more amperage flow through the start winding than it does once the motor starts. This is what 'charges' the run capacitor, so turn off the power, note the position and terminals the wires are on, remove them with insulated pliers and short across ALL terminals to drain the potential charge before touching the spade clips with your bare fingers. Remove the capacitor and read the rating on the side for replacement. Contact just about any local HVAC company for a replacement or go to WWGrainger's website and see if you can buy one retail from them.
The three terminals will be marked 'C' for common, 'Herm' for compressor and 'F' or 'Fan' for the condensor fan. If you get any wire in the wrong place, you could potentially damage the compressor or the fan motor.
BE SURE TO DO THE WORK WITH THE POWER OFF !!!!!!!
Jan 03, 2015 | Heating & Cooling
Danby premiere dpac 12010h does not fully start, shuts off, repeats
Unlikely to be a capacitor but they aren't expensive to replace. More likely to be compressor failing to start, or controller faulty. Try powering up the compressor and fans to see if they run independently of the controller
Aug 07, 2012 | Danby Premiere Series DPAC12010H 12,000...
Armstrong concept 1200-bad start/run capacitor?
Yes, most likely the start capacitor has failed & should be replaced. You have proven this by being able to hand-start the fan. Once replaced, the compressor should kick in & work fine.
Jul 20, 2012 | Heating & Cooling
Fedders 208/230 split system w/ dual cap , compresser runs but fan wont unless you give it a push , compresser won't restart if relay is hot
All kinds of stutt happens when you dont have a condensor fan motor. You need to change the run cap on the motor.
Aug 06, 2011 | Heating & Cooling
My coleman RV AC 8000 series will not run - not even the fan. When I turn it on, I get a hum, and thats all. At one point, I gave the fan a little 'Push" and it ran nice and cold for hours. Once it...
It can be the start capacitor,or the fan itself can be bad,replace the start capacitor,then if this does not help,replace the fan motor,sense you can start the fan by hand,and it runs for hours,it must be the start capacitor.
Jul 27, 2010 | Heating & Cooling
Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
No Fan
If you here a click then check the Relay, open and turn on you should see a black box with wires going to it, (Careful HIGH VOLTAGE!!!!)
Jul 18, 2008 | Danby DPAC8399 Air Conditioner
Danby SAC10504D
possible faulty fan or fan capacitor I'd change can capacitor first if runs there's your problem solved. also if your pretty handy, apply direct power to it if should turn on if good if it does turn on suspect a faulty board or selector switch
May 05, 2008 | Danby DAC8003D Air Conditioner
Fan motor not starting or running
you can try "bump testing" the motor by connecting a separate power cord to fan motor wires. ensure no power to anything else first. if it spins, then check back to control board and control panel.
Jun 05, 2007 | Danby DPAC8020 Air Conditioner
Danby DPAC8399 Air Conditioner Logo
113 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
