Question about Filter Queen Majestic Canister Vacuum
Filter Queen Powerhead Not Working
For quite some time, the plug in for the separate powerhead on the wand hasn't worked right. It would fall out sort of and not work. I would have to keep shoving it in to keep it running. Today it won't work at all. I tried cleaning the contacts and took apart the handle to see if the switch was still wired. As far as I can see, I don't know why it isn't working, but I think the problem is in the handle switch. Any ideas?
  • 65 Answers
Is it the part where the hose connects to the wand or is where the wand connects to the power head? and what side keeps falling out. it sounds to me that its either a hose or a wand issue. unfortunatly the cord itself cannot be replaced and if the problem is a worn out connector in the hose which is possible it would require a replacement hose and if it is on the wand end it would require a new wand. either are fairly cheep on ebay. or you can possibly find one used at a local vacuum dealer. dont buy new. save yourself some money if possible.
Posted on Nov 29, 2008
Filter queen majestic power head not working, main vacuum working but no power in head when plugged in. any suggestions as to what may be the cause for this to happen.
Is there power at the head, have you checked with a volt meter, most likely if not then the cord to the head is defective.
Aug 31, 2016 | Filter Queen Vacuums
Electrolux EL7055 powerhead not working
Have you tried testing the continuity in the hose, wand, and power nozzle? You can also try putting the hose directly in to the power nozzle. If you still need help with you electrolux vacuum try contacting evacuumstore.com
Nov 17, 2013 | Vacuums
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
My Dyson DC17 is picking up on the floor, but the wand is not working. I cleaned out a clog from the port in the back, but the wand still isn't working.
If there's no suction at the end of the wand, check at the end of the hose. If none here, then there's none at the powerhead, so it's not picking up either.
Check the hose. A clog at the tank port generally result in a clog in the hose as well. If none are visible, detach hose completely, hold one end up and drop a coin in. Lifting the hose should result in the coin falling through. Not doing so means a clog. You may be able to push it through with a broom handle. If that doesn't work, try holding the powerhead end of the hose to the tank port. Turn the vacuum on. This may provide enough suction to pull the clog through.
If not, and you have access to a shop vac or air pressure hose and generator, try blowing the clog out with one of these. Or you can buy an air mattress pump and try that.
Mar 09, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Replacing the powerhead motor
depending on which powerhead you have the screw may be under the decal on top of the powerhead. you should be able to feel an indent above the motor. most of the other heads do not have a "hidden screw".
Jun 12, 2008 | Filter Queen Majestic Canister Vacuum
Loose Wand Connection
its just worn, sometimes getting a new lower wand can fix this
Jan 18, 2008 | Vacuums
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
EL5 (large) powerhead
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Nov 27, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Filter Queen Majestic Canister Vacuum Logo
296 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
