Question about Dell 1600n All-In-One Laser Printer
Unlock scanner issues
When I got this company issued printer which has been used previously, it reads unlock scanner and press cancel on the screen. Well I have pulled the tab towards me as far is it can go and hit cancel, still it reads the same thing. I have turned it off, pulled the plug and turned it back on while the tab was in the unlock position and it still reads "unlock scanner and press cancel". Tech support for my company doesn't know what to do. What can I do?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Tab? what tab are we referring to? I know this printer quite well, and I'm at a loss for understanding this aspect?
Posted on Aug 19, 2008
  • dpcw Feb 06, 2011
    If you don't know where the tab is you obviously do not the printer quite well!
MY PRINTER (HP LASERJET M1005 MFP) SCANNER ERROR 12 DISPLAY IN A SCREEN I CAN NOT SOLVE THIS PROBLEM NO SCANNING , NO PHOTO COPY IN MY PRINTER PLEASE HELP ME HOW TO SOLVE THIS PROBLEM
do a reset on the printer. if you have a cancel and right arrow button on the printer
1. disconnect the power while the printer is on
2. press and hold the cancel and right arrow
3. while holding the buttons insert the power cable
4. release it after 30 seconds
it will reset the printer ...
after that if y0u still face the issue the printer has gone bad .. time for new printer
Jun 30, 2012 | HP LaserJet M1005 All-In-One Printer
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
* Entering the simulation mode
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
Sep 07, 2010 | Sharp AL 800 Copier
Need to clear Hard Disk which indicates that it is full I do not have a manual.
I just ran into this issue in teh last couple days. I went back and found a note from someone who owend it previously with instructions on how to clear this.
Press the menu button until you see the "reset". Press enter. On the screen when you see "Clear log/Queses" change the no to a yes with the arrow keys. Press enter and wait a few seconds. Press cancel and the machine will reboot and the hard disk will have been emptied.
Feb 01, 2010 | Canon imageCLASS C2100 Laser Printer
THE SCREEN SAY UNLOCK THE SCANNER AND PRESS CANCEL
I don't know this model in particular, but most machines have a switch underneath the automatic feeder, on the left side of the contact glass.
Please rate solution:)
Apr 21, 2009 | Dell 1600n All-In-One Laser Printer
Lexmark 6100 will not unlock after unlock procedure is done.
Thank you for contacting Fixya.
Please ensure that the scanner is unlocked. The scanner lock is situated under the scanner bed towards the left. To unlock the scanner, please lift the scanner bed and push the red switch towards the back of the machine. Please try scanning again and let us know the results.
If the issue still persist, please follow the steps given below:
1. Press "Copy" button.
2. Press "Options" till the display reads "Set Defaults."
3. Use the "Arrow (right/left)" buttons till the display reads "Use Factory."
4. Press "Select."
Please let us know the results.
Sincerely,
Jeeth
Apr 15, 2009 | Lexmark X6170 All-In-One InkJet Printer
Error on all in one laser printer dell scanner error
take it back to the company where you purchased it at!
Mar 06, 2009 | Dell 1600n All-In-One Laser Printer
Scanner failure
This is a serious hardware issue where you will not be able to copy or scan from the printer. However, printing is still possible. The only possible steps for this issue are Connecting it to a wall outlet directly, and performing a semi full reset..
Disconnect the power cord from the product.
Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
After performing this step, try making a copy. If the issue does not resolve, replacing is the only option available.
Dec 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
2410 photosmart all in one
unplug the power cable
Press and hold # and 6 on the printer while keeping these tow buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on. it ll perform a semiful reset on the printer .
if the issue still persists then unplug the power cable again
Press and hold OK and CANCEL on the printer while keeping these two buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on .
it should fix the issue else call HP CARE and they ll replace it for u
May 22, 2008 | HP PSC 2410 All-In-One InkJet Printer
I Don't Have The Key
Darryl - lift up the top part of the scanner body (the silver part should separate from the black base) and let the kick-stand support the top part. Then look underneath the top part; there'll be a green tab sticking down from the top. If you look closely, you'll see little icons next to it that look like padlocks, one in an unlocked position and one in a locked position. Push the green tab away from you so that it lines up with the unlocked padlock, and that should do the trick.
Feb 10, 2008 | Dell A960 All-In-One InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
226 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
