Tip & How-To about Sony Playstation 3 (PS3) Console
Complete PS3 Error Codes:
0710102 - DNS Error; No DSN server available.
8013030 - System Error due to failed update download
80010001 - Major Error , Game ability stopped
80010006 - An error occurred during the start operation (corrupted folding install)
80010007 - An error occurred during the start operation (during disc swap tests)
8001000B - it happens when trying to establish wireless connection
80010017 - Can't start BlueRay Game
8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown
8001050D - An error during the start operation; Ps3 game swapped using
the eject function and then play pressed quickly - ps3 game inserted
again
8001050F - Hardware failure. Cannot update firmware or connect to internet.
80010510 - Will not play games installed on the hard drive
80010514 - Possibly reading blu-ray disc problem
80010516 - An error occurred during the start operation; Ps1 game
swapped using the eject function and then play pressed quickly - ps1
game inserted again
80023101 - Unknown
80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server
80028EA5 - User cannot connect to PS3 network
80028EA6 - Connection error , Possible Proxy error power cord. Then shut
off your modem/router, for about 5 minutes, then turn the modem back up
first and let it sync, then turn the router back on(if using one) and
let it sync. Reconnect your power cable and flip the back switch up
again. Then make a new network connection.
80028EA8 - Seems to mean unable to authorize isp account details
80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,
80028F17 - Ps2 disc Boot Error , An error occurred during the start
operation; Ps2 game swapped using the eject function and then play
pressed quickly - Backup ps2 game inserted again
80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).
80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it
80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error
80029023 - Exchanging Key Information exchange has timed out
80029024 - "The attempt to obtain an IP address has timed out".
80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card)
80029501 - connection
80029509 - When the PSN network is down for maintenance.
80029513 - This content cannot be accessed on your account (80029513)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them)
80029564 - Downloaded game will not install
80029751 - warhawk wont start but eveything else seems ok
80029945 - Can't playback burn BD movie
80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )
80029C68 - Corrupt data usually on external device
8002A10B. It shows up when I try to view my friends trophies, profile etc.
8002A10D - Unable to Add friend in XMB
8002A4A6 - Cannot load game to play online
8002A515 - Error Signing in
8002A524 - connection
8002A548 - Unable to remain logged in - either to game or server
8002A705 - Unable to connect to server/host. Check router port configuration.
8002AD23 - Unknown
8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually
configuring your PS3 IP info. Try disabling medai server connection in
the PS3.
8002B241 - DVI has no audio.
8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game
8002F994 - Too many people downloading the update (download it later on)
8002F997 - Can not update XMB firmware
80030001 - Deleting messages from inbox
8003041F - An error occurred during the copy operation (using media server)
80030517 - It seems to happen when you copy large media files.
8003051E - Game will not save
80030920 - An error occurred during the copy operation, the file may be
corrupt or there isn't enough memory (Try copying data from original
source)
80031150 - "Setting information is corrupted.Press the x button to repair and restore default"
80031601 - Error Creating Account
8013013D - "A connection error has occurred" - May be to do with the
SSID of the Router or signal strength if the connection drops Putting
the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle
WPA2 only WPA or none
8013013D - connection
8013013E - WEP Key error, change WEP key to all numbers (on router
homepage) and try agian, or which to WPA. - Otherwise disable security
80130203 - PS3 connects to internet but not to network - Typically means
that the required ports are not open to connect to store but PS3 can
8013030F - Access Point not detected
8041040F - Communication with the server failed. A dsn error has occured.
80410418 - DNS Error
80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.
80710016 - Playstation Network is down.
80710092 - "An error has occurred. you've been signed out from the ps
network" , "Media Server Error: A network error has occurred (80710092)"
80710101 - Connection error
80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router
807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error
8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the
back switch and completely remove the power cord. Shut off your
modem/router, for approx. 5 minutes, then turn the modem back up first
and let it sync. Then turn the router back on (if you're using one) and
80710541 - The connection to the server timed out.
80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond
80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode
81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
