Hi! My printer won't work. Keeps coming up open scanner cover reinstall ink cartridge. No Cartridge. I have checked and there is ink in all the cartridges. What now please?
  • suemeikle Jul 27, 2008
    Re my reply..I have replaced two inks and still no luck, keeps saying No Cartridge replace ink. AND the inks aren't empty! Also, having paying because I have BNZ Visa, won't fit.
Thanks for the reply! I found a site called brother.solutions.com who told me to lift the cover and read the LCD which I did and it told me that cyan was empty! Am going to replace this today! Thanks for your concern..
Cheers
Sue
Posted on Jul 22, 2008
Mitsubishi tv keeps turning off.
Hello there please check the following in your tv;
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings
If this does not work then a full system reset should be performed on the control panel by pressing the System Reset button. The television will turn off and the green LED light will flash quickly for a minute. When the light stops flashing, the TV will turn on.
If that still doesn't work, then the projection lamp might need replacing and here is how to do that;
Ensure that the bulb is completely cooled and the television is unplugged. Use a Phillips-head screwdriver to remove the lamp compartment cover. Unscrew the lamp cartridge on the rear of the television. As opposed to the cover door, these screws do not actually come out of their chamber and simply loosen the lamp assembly. Remove the old cartridge and insert the new one. Secure the lamp with screws, then replace the cover and screw in tightly.
Please note that, Finger oils can cause the lamp to malfunction.
Projection lamps are powered by mercury. Wash hands thoroughly after replacing the projection bulb.
GOODLUCK
Jul 04, 2010 | Akai PT61DL34 Television
I have a problem with my epson 9600 it's about 3 years old the black is printing in dart green, I tried to clean the head but no joyed, the reading is showing E*****F for both Head & Cleaner. Can...
Hey,
3 years, its definitely a problem in the printer head or the cardridges, try performing the print head cleaning a few times, also alingment? You can also clean the carts and connectors yourself.
Thanks,
Ekse
Sep 06, 2008 | Televison & Video
I don't have an owner's manual for my wd 60735, but I need to change the bulb. whatt are the steps I should follow?
Removing the Old Lamp Cartridge
Turn off TV power a 1. nd allow the lamp to cool for at
least one hour before proceeding.
2. After the lamp has cooled, remove the cover of the
lamp compartment, located on the back of the TV.
Refer to figures 1 and 2. Use a #2 (large) Phillips
screwdriver to loosen the screw securing the cover.
Keep the screw and cover for re-installation
3. With a large Phillips screwdriver, loosen the two
shiny screws securing the lamp cartridge until they
disengage from the mating threads. These are
captive screws and cannot be separated from the
lamp cartridge.
4. Fully open the bag supplied with the replacement
lamp and set the opened bag aside.
5. Gently grasp the handle of the lamp cartridge and
pull the old cartridge straight out. See figure 3.
CAUTION: Do not tilt or rotate the cartridge, as
small glass fragments may fall out.
6. Without tilting or putting down the lamp cartridge,
insert it into the opened bag. Close the bag while
being careful not to let any glass particles fall out.
Installing the New Lamp Cartridge
1.
Do not touch the glass parts of the new lamp cartridge.
Insert the new cartridge into the TV in the
same orientation as the old cartridge. Push on the
cartridge housing until it is fully seated.
2. With either your fingers or the screwdriver, gently
tighten the two shiny screws. If using a screwdriver,
AVOID OVERTIGHTENING!
3. Replace the plastic cover and retaining screws.
4. WASH YOUR HANDS THOROUGHLY, AS THIS
LAMP CONTAINS MERCURY.
Nov 11, 2009 | Mitsubishi WD-60735 Projection Television
Wd 52525 mitsubishi projection tv
Do the following preventive maintenance and check-up:
  1. Check the lamp cover door, it might be opened then close it firmly.
  2. Check the lamp cartridge if securely installed and tightly secure it.
  3. Clean the dust filter and provide a cooler temperature environment for the TV.
  4. Check the lamp and replace if nether of the above does not solve the problem.
    Tool needed: Phillips screwdriver
    1. Turn the television off and unplug the AC cord.
    2. Remove the front speaker grill by gently pulling
    on each side. The grill will snap out.
    3. Using a phillips screwdriver, remove the three
    screws (one on the left and two on the right side)
    that hold the recessed plastic cover in place.
    4. Remove the plastic cover and set aside
    with the screws.
    5. After removing the cover, you will be able to
    see the lamp cartridge. With the screwdriver,
    loosen the three screws of the cartridge.
    The three screws will not completely remove .
    6. Gently grasp the metal handle and pull
    straight out (towards you).
    7. Insert the new lamp cartridge securely
    into the TV. Do not touch the glass surface
    of the cartridge.
    8. With the screwdriver, tighten the screws
    on the lamp cartridge.
    9. Replace the plastic cover and screws.
    10. Snap the speaker grill back into place
    by pushing it into place on each side
    with the palm of your hand.
Aug 07, 2009 | Televison & Video
My hp 1350 printer is saying cartridge error I have replaced these and there is no difference. Red led light keeps flashing (check cartridge)
Try cleaning the contacts in the cartridge holder with some isoproyl alcohol on a q-tip. If that still does not work, then try reinstalling the driver after uninstalling it first. Should the issue still continue, then it indicates a sensor problem, for which servicing will be required.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Sep 28, 2008 | Televison & Video
Fixed new colour cartridges, and they are saying that the colour cartridges are empty and they are full
please check whether the printout is coming proper when you give a print.
if its coming proper the cartridge is proper.this message is shown because in the printer there is a sensor which detects where there is a ink in the cartridge or its empty.so if the printouts are coming properly the sensor is bit moved from its orignal position or the sensors are damaged and became faulty to detect the ink in the cartridges.
so you use the cartridges let it detect no ink print out will come till the end of the ink.
or if still the prints do not come try changing the cartriges .
Sep 24, 2008 | Televison & Video
I have a z640 lexmark printer, which side does the black ink cartridge go? the left or the right?
Black cartridge usually goes to the right.
Check here for instructions
Black cartridge is the one on a darker green color.
Sep 07, 2008 | Televison & Video
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
