Question about Disney D7500PDD Portable DVD Player
The screen connector that connects the two screens is not working anymore. I need to purchase a new one that will fit the screens. Where do I purchase this ? As of right now, we can only use the first screen not the second. I have two kids and that is more harm than good. Please help!
I have found a person that has the power cords. We got the same run around about the Disney supplier getting the parts in a "few weeks". I happened to come across Jamie on Ebay. He had refurbished players and mentioned that he had power cords. I bought two power cords from him in case I needed one in the future. I received them today and they are exactly what I was looking for. I don't know if I can give out email address so I will give you his Ebay seller ID. It is oshog23. I bought them for $10 each and it included USPS Priority Mail.
Posted on Apr 06, 2009
I had this problem and searched high and low for the cable that had a power cable and the green & yellow A/V cables. I couldn't find one anywhere. I visited my local Radioshack and found the solution! Since the second screen wasn't getting any power, I thought I would just plug the power cord into that screen to see if that would at least make the light turn green. It did have power. So, I asked the manager at Radioshack if there was a way to just get the power cable. He led me to the "Adaptaplug" 6-Ft. power cord (product # 2731740) and the two "Adaptaplugs" that would fit the units (product #2731705). They are "Adaptaplug-B" 0.4mm O.D. 1.7mm I.D. The cost for this was $23.24 I hope this solves your problem. It sounds exactly like what mine was doing. This seems a little high, but it is well worth it to my twins!
Posted on Aug 02, 2008
    Problem Solver:
  • 8 Answers
THE MAN FROM DISNEY ELECTRONICS CUSTOMER SUPPORT SAID THEY WOULD BE STOCKING PARTS BUT IT WOULD BE 3-4 WEEKS 1-612-344-47330 TODD?
Posted on Sep 22, 2008
How to replace display of ir2800
  1. Open the Right door.
  2. Open the two screws Marked as 1and 4.
  3. Open Last One screw Left side a hole in Display.
  4. Remove the connector with safety.
  5. Open the 4 Screws back side of the display.
  6. Disconnect all the Connectors.
  7. Remove all the Circuits.
  8. Remove all the Self threaded Screws.
  9. And Remove the Iron Base Plate.
  10. And Safely replace the Display with new one.
  11. Place the Touch Screen Properly.
  12. And reinstall The Iron Base Plate.
  13. Place all the Circuits.
  14. Connect all the Connectors as connect they before disassemble.
  15. Reinstall Properly the Display as Before It Place.
  16. Now on the machine and check it...boom boom..
Do not Do That:
  1. Do not use Thinner and Hard stain remover Acids.
  2. Do not clean the circuits with liquids.
  3. Connect all the Connectors at Proper port.
  4. Place the screw well fit to display and touch screen to work touch screen properly.
  5. Do not give room with Display and Touch it may not work properly.
May 14, 2016 | Canon Ir 3300 Black & White Copier
How do I connect a 20X super all write to a Dell Dimension 1100 computer .The pins on the data lead apear to be different and the power lead apears to be missing from the unit I purchased.
To my understanding, your new Lite-On LH-20A1L 20x Super AllWrite DVD±RW/RAM is a SATA whereas your Dell Dimension 1100 has only DMA/ATA-100 (Ultra) EIDE. it will not work nor the connectors fit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 30, 2008 | Computers & Internet
The screen won't turn on anymore after I took it apart to switch out the charging port.
I see a crack in screen on top right but it should still display (however touch won't work). Look at the ribbon connector which connects display to the phone PCB, it should be firmly secure in its connector.
Also try cleaning the PCB with alcohol, if still doesn't work then either you need a new LCD or some chip is blown.
Nov 10, 2012 | Lands Phones
Bottom right hand corner of screen un-responsive
Yes you can. All you need is a touchscreen, not an actual LCD screen, the touchscreen sits on top of the LCD. You can purchase them for about £4 on ebay and they are relatively easy to fit. Have a look on the internet for a guide to replacing the touchscreen, there are lots out there. They do have quite a fiddly connector though so if you have big fingers you might want to get some tweezers ready :)
Hope this helps
Aug 02, 2010 | Nintendo DS Lite Console
JUST REPLEACED LCD R52 AND THE SCREEN IS BLACK
You replaced the broken LCD screen in your laptop with a new screen but it’s not working.
Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
You did some research and purchased a compatible screen, installed it into the laptop, turned it on and… The new screen is not working!!! What could be wrong?
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
The video cable has to be seated properly, all the way down.
Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCDs have a different type of connector, without fragile pins inside.
OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no backlight.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the backlight inside the old screen lights up, apparently the new screen has defective backlight lamp and has to be replaced.
Oct 14, 2009 | IBM ThinkPad R52 Notebook
Both screens on my bb 8220 flip phone do not work phone still works though
check the connection between mother board and the screen.Its a flex/ribbon cut-not working anymore.better to replace a new flex/ribbon for you Flip BB.
Jul 16, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Need to remove lcd
Hello
These are the tips you should follow. This is my solution regards about my laptop problem.
You replaced the broken LCD screen in your laptop with a new screen but it’s not working. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible withthe old one. Different screens require different video cables. Makesure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in yourlaptop. A part of the screen still works fine but you cannot use itlike that so you decided to replace the screen yourself.
screen-not-working-1.jpgYou did some research and purchased a compatible screen, installedit into the laptop, turned it on and… The new screen is not working!!!What could be wrong?
Before you start to panic, check all cable connections again. Checkconnection between the video cable, LCD screen and inverter board.Reconnect cables just in case.
screen-not-working-3.jpgTake a closer look at the connection between the video cable and LCDscreen. It’s possible you accidentally pulled the video cable from theconnector during the screen installation.
screen-not-working-4.jpgThe video cable has to be seated properly, all the way down.
screen-not-working-5.jpgAlso, on some older LCD screens there are very thin pins inside theconnector. Take a look inside the connector, make sure there are nodamaged (bent) pins.
screen-not-working-6.jpgOK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one worksproperly (except the damaged area) but the new one is dead, apparentlythe new screen is defective and has to be replaced.
If that’s the case, disconnect the new screen from the inverterboard and plug in the old screen instead, as it shown on the picturebelow. If the backlight inside the old screen lights up, apparently thenew screen has defective backlight lamp and has to be replaced.
Good luck !!
ICmanServer
Jul 09, 2009 | Computers & Internet
Sony DSC-W100
This address has the LCD screen for W100 for 49.99 plus 7.99 shipping. http://us.nine.ebid.net/perl/auction.cgi?auction=1223771623-19276-1&mo=auction&from=froogle. I had the same problem with my w100. Just remove the screws that hold the back on. Gently take out the LCD screen and follow the connection to where it connects. Gently pop open the connector clamp, its hinged on the far side. remove the old replace the new snap connector clamp back down. Check that it works then put back and screws back on.
Jul 10, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Charger will not fit anymore
If you got a USB cable with the unit, you can connect to your PC and recharge the battery that way. Just be sure to have the power switch turned ON. The screen on the player will indicate its connected and you should see the battery indicator in the lower right corner showing a charging condition (bar moving)
Feb 12, 2008 | Audio Players & Recorders
Disney D7500PDD Portable DVD Player Logo
563 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
