Question about Kenmore 63074 Top Freezer Refrigerator
Fridge not cold freezer workes - Kenmore 63074 Top Freezer Refrigerator
  • 1 more comment
  • Spunkers Oct 03, 2008
    One month old Kenmore, 18.3, top freezer, fridge below. Freezer builds up with frost, vents frost over, fridge gets warm. We have an internal ice-maker which is working fine. The fridge worked great for awhile, now this keeps happening. I manually defrost it and make sure the vents are clear, but within a week, it starts to frost up again.
  • Anonymous Feb 22, 2009
    freezer is ok, fridge is dead!
  • depewsweety May 11, 2010
    i have a whirlpool refrigerator and the freezer is on top and the fridge on the bottom. The freezer works however gets frost and the fridge just stopped working. Where is the compressor on this fridge? I have only had the fridge for 4 years. I bought it at Aaron's rental. It is at least 18 cu ft.
  • Kenmore Master
  • 43,501 Answers
Posted on Aug 12, 2010
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
Fridge Freezer not cold
Is there a fan inside the freezer compartment to direct cold air to the fridge? Check it's working. If not fanned, check rear wall of fridge. If not cold, unit may be short of gas.
Apr 20, 2014 | Refrigerators
Bottom freezer left open overnight. Freezer does not work anymore. Top fridge does not getting cold as it should be.
Your fridge gets it's cold air from the freezer. If the freezer is not working then the fridge won't get cold.
May 26, 2011 | Refrigerators
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
Freezer works, fridge part does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 21, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 63074 Top Freezer Refrigerator Logo
97 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
